Torque inserts on a Spiral cutter
Forum topic by nitehorse posted 11-22-2018 05:06 PM 488 views 0 times favorited 5 replies Add to Favorites Watch
View nitehorse's profile
nitehorse
72 posts in 727 days
11-22-2018 05:06 PM
I have a new G0453Z I am about to set up. To be safe I want to check the torque on the inserts.
What size or type of torque wrench to set the inserts?
If so any preference on the wrench’s range and size.
I was thinking of a 3/8 with a 10-80lb range.
Any and all advice on the above or setup in general will be appreciated.
Thanks
Jim
5 replies so far
View waho6o9's profile
waho6o9
8812 posts in 3184 days
#1 posted 11-22-2018 05:12 PM
7. Lubricate the Torx screw threads with a very small amount of light machine oil, wipe the excess off, and torque the screw to 50–55 inch/pounds.
https://cdn0.grizzly.com/manuals/g0453z_m.pdf
Best of luck!
View Aj2's profile
Aj2
2650 posts in 2405 days
#2 posted 11-22-2018 05:16 PM
Are you looking at wrenches for inch pounds. Not ft pounds.
I wouldn’t mess with it yet because they are easy to crack. But then I understand your concerns. I dont trust strangers with my machinery set up.
-- Aj
View TheFridge's profile
TheFridge
10859 posts in 2093 days
#3 posted 11-22-2018 05:34 PM
If it’s a Byrd head I wouldn’t worry.
I bought a 1/4” in-lb torque wrench and it was at the very low end of its range if I remember correctly.
5929 posts in 3101 days
#4 posted 11-22-2018 05:53 PM
I have one that looks like a screwdriver I use, my inserts only get set to 45 inch pounds (Byrd).
nitehorse
#5 posted 11-25-2018 07:19 PM
Thank you all.
Yes I am looking for a in/lbs torque wrench.
I have read that it is a good idea to check the factory settings and also the inserts are a bit finicky to get set in place properly. We shall see :)
After some more on-line searching it seems the screw driver type might be the way to go. RAK and Vortex have decent reviews. I truly do not know how much hand strength is needed but I will see if I can try one out at a store.
Jim
