Ideal Height for a drum sander?
Forum topic by RevenantJoiner posted 11-21-2018 05:17 PM 1018 views 0 times favorited 14 replies Add to Favorites Watch
View RevenantJoiner's profile
RevenantJoiner
30 posts in 953 days
11-21-2018 05:17 PM
Topic tags/keywords: question tool base drum sander base
I recently purchased a used drum sander. I now need to make a base for it. What is the ideal height for the drum sander belt to be from the floor? What height are the commercial bases? Does that work for those of you that have these? If not, what would be your recommendation?
Thanks for any and all information and suggestions.
Tom
-- Each time your start a project and work on it, a tree smiles knowing there’s life after death.
14 replies so far
View 000's profile
000
2859 posts in 1501 days
#1 posted 11-21-2018 05:31 PM
I prefer mine to be at bench height, (approx 34”)
View xeddog's profile
xeddog
270 posts in 3609 days
#2 posted 11-21-2018 05:32 PM
Seems to me that the best height is the one that would be most comfortable for you. It would be higher for someone 6’4” than for someone 4’6”.
Wayne
View pottz's profile
pottz
7644 posts in 1586 days
#3 posted 11-21-2018 06:20 PM
i have a jet and mine is about 34” but like wayne said its all about what works for you.
View GaryCK's profile
GaryCK
74 posts in 651 days
#4 posted 11-22-2018 12:45 AM
My SuperMax on its factory mobile base sits at about 34.5”. That’s a comfortable height for me at 6’-0” for what that’s worth.
-- Gary, Wisconsin
View JAAune's profile
JAAune
1872 posts in 2919 days
#5 posted 11-22-2018 01:38 AM
Pickup a long board and hold it level at the most comfortable position. Measure the height of the board from the floor while in that position (or have someone else do it). An inch or two lower than that makes for a good table height for machines like drum sanders and planers.
View splintergroup's profile
splintergroup
3195 posts in 1824 days
#6 posted 11-22-2018 03:24 PM
You spend a lot of time standing at the sander feeding and retrieving boards at the drum. Make the height such that you don’t need to bend your back….
View Redoak49's profile
Redoak49
4343 posts in 2591 days
#7 posted 11-22-2018 04:09 PM
You spend a lot of time standing at the sander feeding and retrieving boards at the drum. Make the height such that you don t need to bend your back….
- splintergroup
This is the best answer and why I have mine fairly high as are all my tools. I am 6’ 3” with a bad back.
pottz
#8 posted 11-22-2018 04:57 PM
i have most of my tool stands and benches higher than average.my miter saw and ras are about 43” and my assembly table is about 38”.too much bending over kills the back,trying to make last until i expire-lol.
View bigJohninvegas's profile
bigJohninvegas
722 posts in 2064 days
#9 posted 11-22-2018 09:17 PM
I have my work bench and thickness planer set at the same height as my table saw.
Workbench makes a good out feed table, I will have a drum sander sometime next year, I hope.
will most likely set it up the same way.
-- John
View WoodenDreams's profile
WoodenDreams
881 posts in 513 days
#10 posted 11-23-2018 10:36 PM
As they say. height depends how much you want to bend over. It’s not a bad idea to have it a couple inches higher than needed. Easier on your back from bending over.
View bruc101's profile
bruc101
1377 posts in 4144 days
#11 posted 11-23-2018 10:49 PM
The older you get, the straighter you’re going to want to stand.
-- Bruce Free Plans https://traditionalwoodworking.org
View Dark_Lightning's profile
Dark_Lightning
3750 posts in 3711 days
#12 posted 11-25-2018 12:13 AM
I put my lunchbox planer and drum sander in a stack, because I’m really challenged for floor space. The planer is about 5” at the infeed/outfeed plates, and the sander is at 29”. I just do squats when I feed the wood through the planer. Works for me, because I don’t thin out wood much. The sander is actually a good height for me, at 5’9” and having ape-like arms. My lathe is set up for ergonomics at 36” where my forearm is even with the center line of a turning. Just got that set up a few weeks ago. I’m going to get around to using it soon. Same with the table saw, the scroll saw and small (9”) band saw. The bigger band saw (12”) is a little high, but not unworkable.
-- Steven.......Random Orbital Nailer
View theart's profile
theart
153 posts in 1156 days
#13 posted 11-26-2018 05:43 PM
- bigJohninvegas
Same here. I have a small shop, and it’s nice to be able to use the same rolling outfeed table for both the table saw and planer.
View wncguy's profile
wncguy
471 posts in 2914 days
#14 posted 11-26-2018 07:09 PM
I recall many, many years ago asking my Dad how high to make a workbench… His response was “pecker high”.
In hindsight, seems good to me.
Guess another reason I loved him & wish I’d told him that more often.
-- Any man can be a father, but it takes someone special to be a Dad
