Source for 60 Degree Dremel Cutters
« back to Coffee Lounge forum
Forum topic by Jim Jakosh posted 11-12-2018 05:45 PM 2051 views 1 time favorited 46 replies Add to Favorites Watch
View Jim Jakosh's profile
Jim Jakosh
23740 posts in 3709 days
11-12-2018 05:45 PM
Topic tags/keywords: resource
I am in need of a 60 degree 1/8” shank cutter for a Dremel for thread cutting in wood on my metal lathe.
I have some of these cutters ( below) from Kent’s Tools in Tucson but they are about a 30 degree angle and he cannot get a 60 degree version.
Does any one know of a source for such a bit (1/8” shank, 60 degree V and about 1/2” diameter head) in HSS or carbide?
Thanks, Jim
46 replies so far
View rance's profile
rance
4271 posts in 3764 days
#1 posted 11-12-2018 06:41 PM
https://www.chefwarekits.com/ez-threading-pro-xl-jig-thread-cutter/ez-threading-pro-60-degree-cutter-hss.html
EZ Threading Pro 60 Degree Cutter (HSS)
Product Code: 570
Availability: In Stock
$29.95
They are used on the EZ Threading jigs they sell.
Rance
View HokieKen's profile
HokieKen
11985 posts in 1742 days
#2 posted 11-12-2018 09:51 PM
Is this for cutting internal or external threads Jim?
If internal, I don’t know of anything. The bit rance linked would work if you have a way to grind the shank down to fit your Dremel.
If cutting external threads, could you turn the dremel so it’s perpendicular to the lathe axis and use a 60 degree v-bit to cut the threads?
-- Kenny, SW VA, Go Hokies!!!
25952 posts in 4454 days
#3 posted 11-13-2018 12:30 AM
Jim, I purchased a similar tool from a US address
use-enco.com
400 Nevada Pacific Hwy., Fernley, NV 89408
800-USE-ENCO (800-873-3626)
email : [email protected]
View bushmaster's profile
bushmaster
3770 posts in 2886 days
#4 posted 11-13-2018 04:21 AM
Interesting, great mind think alike. I had been looking for a cutter to cut threads on the metal lathe for wood boxes etc. by using the metal lathe thread cutting gears I reasoned I could cut any thread. Only trouble is I could not find a cutter. Sounds like they are available. Let me know if you find a good source. I would rather have a 1/4 inch shank. The first reply is 3/8.
-- Brian - Hazelton, British Columbia
Jim Jakosh
#5 posted 11-13-2018 01:33 PM
Thanks Rance. That would work if it were a 1/8” shank. I’m using a Dremel in place of a too bit.
Hi Kenny, I want to do both on the same piece. I can turn the parts on my wood lathe and then change the bushing in the back of the chuck to 1 1/2”-8 and put it on my Southbend lathe for threading. I have done that for several projects but I always get some chip out from the scraping action of the tool bit in wood…and sometimes I scrap out the piece if it is too bad. i have carefully turned 1/4” shanks down to 1/8” but for this, that shank might be hardened and quite heavy on the business end for a 1/8” shank.
Hi Tony ..Thanks. I just sent Enco an E mail with pictures. I’m also checking with Production Tool here in GR tomorrow
Hi Brian..we sure do think alike. I’ll bet you are using a die grinder with a 1/4” shank. I guess it would with my V block holder, so I could to.
On of my LJ and guild buddies sent me this video of the threading jig and I gave it some thought and then I said, said I , I already have a big threading tool I just need a high speed rotary tool bit.
Here is the video: https://www.youtube.com/watch?v=0Muw0zP6elg
cheers, Jim
View GR8HUNTER's profile
GR8HUNTER
6807 posts in 1316 days
#6 posted 11-13-2018 03:09 PM
you guys are
SUPER DOOPER :<))
HokieKen
#7 posted 11-13-2018 03:18 PM
Hi Tony ..Thanks. I just sent Enco an E mail with pictures. I m also checking with Production Tool here in GR tomorrow
cheers, Jim
- Jim Jakosh
In case you don’t get a response, Enco is no more sadly. They were purchased by MSC some years back and eventually absorbed entirely. I imagine your message will be forwarded to MSC customer service. But, you can also have a look at MSC's website in the meantime.
Jim Jakosh
#8 posted 11-13-2018 04:48 PM
Thanks, Kenny . I’ll do that. I didn’t know they are no more. Enco always had some good reasonably priced tools!! I bought my mill vise from them many years ago!
cheers, Jim
HokieKen
#9 posted 11-13-2018 04:52 PM
Yep, a lot of machinists were sad to see Enco go away. They sold a lot of good tooling at fair prices. When you didn’t need a Starrett, an Enco would do! MSC has some good values too but it’s a lot harder to sift through their massive catalog…
Jim Jakosh
#10 posted 11-13-2018 08:01 PM
You’re right , Kenny. I have an older one and it is 1 1/2” thick. I find most of the stuff I need on E bay..tools, cutters, belts bearings..etc so I don’t go the MSC much. I can’t find that cutter on there, though
Cheers, Jim
View Joe Lyddon's profile
Joe Lyddon
10859 posts in 4656 days
#11 posted 11-13-2018 08:28 PM
Thanks Rance. That would work if it were a 1/8” shank. I m using a Dremel in place of a too bit.
Hi Brian..we sure do think alike. I ll bet you are using a die grinder with a 1/4” shank. I guess it would with my V block holder, so I could to.
cheers, Jim
- Jim Jakosh
Jim, don’t you have an extra Router sitting around doing nothing?
That bit that Rance found looks good to me… Bummer on the 3/8” shank needing a Collet too! Why didn’t they make a more standard 1/4” shank bit?
That Youtube video looks great and it looks SO SIMPLE!!
I wonder if one could use a coarser Threaded Rod to cut more Heavy Duty Threads… using the same bit?
Looks REALLY GOOD!!
-- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: https://www.ncwoodworker.net/forums/index.php
HokieKen
#12 posted 11-13-2018 08:38 PM
You re right , Kenny. I have an older one and it is 1 1/2” thick. I find most of the stuff I need on E bay..tools, cutters, belts bearings..etc so I don t go the MSC much. I can t find that cutter on there, though
Cheers, Jim
- Jim Jakosh
Yeah me either. I didn’t look for too long but wasn’t having any luck. The 1/8” shank is probably the killer.
HokieKen
#13 posted 11-13-2018 09:13 PM
This has been bugging me Jim because it’s very likely I’ll want a similar tool. So I figured, if you can’t buy it, make it! I also figured that if I need to make it, somebody else probably already has. And done it better…
I was right :-) Here’s a method to make an ID/OD thread tool that’s pretty simple from O1 drill rod. You could pretty easily turn it on the lathe then just grind the head if you don’t have the means to mill it. He makes this to use as a turning tool but if you ground one of the tips off for clearance, I don’t see why you couldn’t spin it in a dremel. It would be a single point tool but if you’re cutting wood, that’s probably fine.
#14 posted 11-13-2018 10:52 PM
Yes I thought it was a bit strange the Enco website did not come up.
Jim, here is a link to my thread cutting jig.
http://lumberjocks.com/projects/221306
Jim Jakosh
#15 posted 11-13-2018 11:12 PM
Hi Joe, that 8 TPI on the shaft is pretty coarse already. I was thinking of using about 11 1/2 TPI like the PVC pi;e threads.
Hi Kenny, the 1/8” shank is the stopper. I might have to go to a 1/4” die grinder. Funny you should say that about making one. I have a design drawn out today with a 60 degree head with 3 holes in it like the one flue countersinks with a hole through them. I’m going out to buy the tool steel tomorrow if they can’t get me one at Production Tool ( same place I buy the steel)
Hi Tony, that is quite a setup you have and it looks like it works super!! Nice looking threads. I made those hand tools but the different woods do not cut clean and can ruin a nice piece.
Cheers, Jim
showing 1 through 15 of 46 replies
