Trying a new table saw blade - Leuco
Forum topic by bluephi1914 posted 11-12-2018 02:35 AM 1048 views 0 times favorited 6 replies Add to Favorites Watch
View bluephi1914's profile
bluephi1914
103 posts in 2608 days
11-12-2018 02:35 AM
Took a chance on this blade and I must say that I have been impressed. New, it Cuts just as good as my frued and diablo blades. Carbide has plenty of meat of them and the blade is solid. I needed something for plywood and still can’t bring myself to pay $125+ r the Forrester blades even though I’m sure they’re worth every penny and then some. After I get some usage out of this blade I will purchase a combo and a rip blade. German steel, German company, but they have a factory in Georgia code to my house that I stumbled upon. They take walk in purchases and phone orders. Blade was less than $70
-- Jack of all trades and a master of most of them.
View waho6o9's profile
waho6o9
9077 posts in 3827 days
#1 posted 11-12-2018 02:38 AM
Looks like a lot of carbide for the money, wise purchase I’d say.
View AHuxley's profile
AHuxley
874 posts in 4571 days
#2 posted 11-12-2018 03:04 AM
Leuco is a higher end tooling company that caters to mostly industrial customers. They are similar to Everlast, Leitz, Popular and Royce Ayr. They tend to have very large carbide teeth for many sharpenings but some of the blades from less industrial facing companies offer better finish but usually less beefy teeth. Obviously, there are tradeoffs for each option. In the end, Leuco makes excellent tooling.
bluephi1914
#3 posted 11-12-2018 03:39 AM
- AHuxley
Ok, good info to know. What other brands were you speaking of that might produce a better cut? Royce and lietz?
AHuxley
#4 posted 11-12-2018 04:49 AM
- bluephi1914
Actually, it is the less industrial blades that will sometimes leave a better cut. For example, the Freud Premier Fusion may give the best crosscutting finish of any general purpose table saw blade due to their low clearance side grinds. The negative to that is they will loose their very sharp edge quickly as a result and require more frequent sharpening to maintain that level of cut. Most industrial tooling leans toward giving a good enough finish for a very long period of time vs an exceptional finish for a short period of time. As a hobbyists I often find myself chasing the best possible finish off a machine when it doesn’t impact the final product, large commercial endeavors are concerned about good enough at each stage (due to money) even if their final finish is equal or better than mine. Their approach is smarter. In the end the Leuco will probably cost you much less per cut than a Freud Industrial line, Forrest or Ridge Carbide over its life but there may be a short time when new or after sharpening the best from those brands may have an advantage in cut quality but not one that translates to a higher quality end result.
Bottom line I think you will be very happy.
View recon49's profile
recon49
16 posts in 1255 days
#5 posted 11-12-2018 05:32 AM
Nice choice. You can’t go wrong with Leuco!
bluephi1914
#6 posted 11-12-2018 04:45 PM
- bluephi1914
Actually, it is the less industrial blades that will sometimes leave a better cut. For example, the Freud Premier Fusion may give the best crosscutting finish of any general purpose table saw blade due to their low clearance side grinds. The negative to that is they will loose their very sharp edge quickly as a result and require more frequent sharpening to maintain that level of cut. Most industrial tooling leans toward giving a good enough finish for a very long period of time vs an exceptional finish for a short period of time. As a hobbyists I often find myself chasing the best possible finish off a machine when it doesn t impact the final product, large commercial endeavors are concerned about good enough at each stage (due to money) even if their final finish is equal or better than mine. Their approach is smarter. In the end the Leuco will probably cost you much less per cut than a Freud Industrial line, Forrest or Ridge Carbide over its life but there may be a short time when new or after sharpening the best from those brands may have an advantage in cut quality but not one that translates to a higher quality end result.
- AHuxley
Gotcha, If I can continue getting this quality of cut from this blade for an extended amount of time then I’ll go with this brand exclusively;
The cut quality is awesome and I hope it can hold its edge for as long as the frued or Forrest and other top brands.
If it does then it’s a win
