Polly over shellac
Forum topic by lumbering_on posted 11-12-2018 01:31 AM 808 views 0 times favorited 15 replies Add to Favorites Watch
View lumbering_on's profile
lumbering_on
578 posts in 1093 days
11-12-2018 01:31 AM
Topic tags/keywords: question finishing
I’ve heard many times that I shouldn’t put polly over shellac, but I’m helping a buddy of mine refinish his coffee table and he’s had a bad time with rings from people not using coasters. Normally, I would just use polly, but he insists that he likes the look of shellac.
Anyone have any trouble with putting polly over shellac, or is it something you can do?
15 replies so far
View bandit571's profile
bandit571
24359 posts in 3286 days
#1 posted 11-12-2018 03:41 AM
Get the De-waxed Shellac….and then Poly will stick to it….it is the waxed shellac you would have trouble with. Been using an Amber “sealcoat” from Bullseye. No problems.
lumbering_on
#2 posted 11-12-2018 04:18 AM
Bandit, thanks for the info. Just a quick question, as I’m not a shellac expert. The normal Bullseye is a 3lbs cut, but Sealcoat is only 2 lbs, would that just need an extra coat, or is there an extra step involved? Thanks.
bandit571
#3 posted 11-12-2018 04:53 AM
Used to be, I “cut” the 2lbs down to 1 lb, with De Natured Alcohol….lately, I just brush it on, right from the can. I usually go with 2 coats Shellac, then a coat or two of Poly, depending on how the first coat looks.
Coat of weathered oak stain, 2 coats of amber shellac, one coat of poly clear gloss…
Wood is Ash.
View TheFridge's profile
TheFridge
10859 posts in 2089 days
#4 posted 11-12-2018 06:01 AM
Haven’t had a problem.
View Hermit's profile
Hermit
239 posts in 1928 days
#5 posted 11-12-2018 09:34 AM
Here’s a video that might help you out from the wood whisperer
https://youtu.be/7kCnmW6mKCM
-- I'm like the farmer's duck. If it don't rain, I'll walk.
lumbering_on
#6 posted 11-12-2018 02:44 PM
Bandit, nice work. Good to know this should work.
Hermit, thanks for the link.
View MJCD's profile
MJCD
601 posts in 2974 days
#7 posted 11-12-2018 02:49 PM
I often use SealCoat under poly. It is critical to allow the SealCoat to fully cure.
MJCD
5922 posts in 3096 days
#8 posted 11-12-2018 05:44 PM
I think you’ll have a problem outside of varnish/shellac. If that table has ever been waxed with some of the aerosol stuff used by many homeowners you might find a problem called “fisheye”. I suggest you give it a thorough cleaning first (TSP works well) then coat it with the shellac. If the cleaning misses any, the shellac will seal it in. If you are 100% posilutely sure it’s never been contaminated with silicone, then your good to go (following the above).
117905 posts in 4180 days
#9 posted 11-12-2018 05:51 PM
Shellac is compatible with all finishes with perhaps the exception of Milk Paint ,this is why you can use it in between types of finishes that are not compatible with each other.
https://www.artisticwoodstudio.com/videos
lumbering_on
#10 posted 11-12-2018 06:34 PM
I think you ll have a problem outside of varnish/shellac. If that table has ever been waxed with some of the aerosol stuff used by many homeowners you might find a problem called “fisheye”. I suggest you give it a thorough cleaning first (TSP works well) then coat it with the shellac. If the cleaning misses any, the shellac will seal it in. If you are 100% posilutely sure it s never been contaminated with silicone, then your good to go (following the above).
- Fred Hargis
I’m not sure what he’s used, so my plan was to use paint stripper, then sand it down. It’s not a veneer, so I don’t anticipate any issues. Do you think I should use TSP in these steps? I generally only use it when I’m repainting as it saponifies the grease, but I not exactly sure how that would work with silicone based wax.
#11 posted 11-12-2018 07:37 PM
If you use the stripper, and then sand it down I would think you would have done as much as possible to mitigate any contamination and you probably wouldn’t need the TSP. I would probably still use the seal coat just to be safe. Silicone can be really hard to remove depending on how much there is.
View Holbs's profile
Holbs
2258 posts in 2632 days
#12 posted 11-12-2018 09:21 PM
to my understanding…using the regular BullsEye Shellac with wax under Poly creates a problem because the wax ingredient micro cracks as time goes by. I found this out AFTER my plantation shutters. So far so good a year after but I fully expect issues in the next couple years.
Or maybe it’s not micro cracks but the wax changes of hue color a slight degree to be noticeable under the Poly. I forget :)
View OSU55's profile
OSU55
2498 posts in 2593 days
#13 posted 11-15-2018 09:12 PM
Not sure about micro cracks, I think its just the wax thats in the shellac which affects adhesion. No issue using dewaxed shellac under poly or a wb finish. For a refinish the shellac can help seal previous sins, but not sure it helps anything under ob poly on unfinished wood. Do you know what the previous finish was that allowed water rings? Never had a problem with them with a properly applied ob poly finish.
View WoodenDreams's profile
WoodenDreams
882 posts in 514 days
#14 posted 11-16-2018 05:15 AM
For client I took a old rocking apart , and replaced all the connecting joints, then put poly over the shellac when I was done. They were ok with putting poly over the shellac cause they didn’t want to spend the extra money for me to remove the shellac. The Poly is holding up.
#15 posted 11-16-2018 11:37 AM
It’s what OSU55 said, the adhesion problem is why it’s often suggested to not use shellac under urethane finishes. But the problem isn’t actually the wax; it’s the urethane resins, which tend to inhibit adhesion. So using dewaxed shellac solves the problem, or using any finish that doesn’t have urethane resins. If you use an alkyd resin varnish (P&L 38, or SW Fast Dry Oil Varnish) it doesn’t matter what shellac, if any, you put under it. It should be said, there isn’t a guarantee you will have problems if you put urethane finishes on top of waxy shellac….just that you might have problems. But the risk isn’t worth it to me, so it’s the old ounce of prevention beats a pound of cure thing.
