Forum topic by Oldschoolguy | posted 11-07-2018 03:31 PM | 1138 views | 1 time favorited | 11 replies | ![]() |
Hi y’all. I am wanting to building a project from a magazine. The plans in the magazine are shown to be printed on graph paper with each square 1/2”. How do I make a drawing in full scale? I have a serious learning disability in that I have trouble with some written directions. Therefore, If you could make your directions as simple as possible, that will ease my mind and make life easier. Thanks to everyone for your directions, suggestions or feedback. |
11 replies so far
#1 posted 11-07-2018 03:42 PM |
first you need to make a scale IE: 1/2” = 1 FOOT SO 6 blocks would be equal to 6FOOT :<)) -- Tony---- Reinholds,Pa.------ REMEMBER TO ALWAYS HAVE FUN :<)) |
#2 posted 11-07-2018 03:47 PM |
Depends on the project. It sounds like it’s already laid out on a graph. Is so, every square = 1/2”. If I line goes through 10 squares, that would mean it’s 5” long. Number of squares * .5 = Length in inches. Does this make any sense? Rich -- https://www.2dogswhiskey.com/ 10% off all products with code LJ10 https://www.facebook.com/2DogsWhiskey/ https://www.instagram.com/2dogswhiskey/ |
#3 posted 11-07-2018 03:56 PM |
Exactly what Tony says, except that it’s possible that they use a scale such as 1:8, 1:24, 1:32 or worse metric. So one square may not give such a nice conversion. However, it is always the same technique of multiplying the measurement on the drawing by the second number after the colon – e.g. on a 1:24 scale if you have 1/2” you multiply that by 24 to get 12” or 1’. |
#4 posted 11-07-2018 06:07 PM |
You could “re-draw” the plans on paper with full size or larger squares (you might have to make you own grid), then copying by hand the lines square by square. I have used this method by overlaying a picture of a object (of known dimensions) with a grid so I can re-draw the outline on a larger grid. Another way is to scan it into a computer and then expand the drawing to the size you want and print it out. That may end up too large for one sheet of paper so it will be printed on several sheets of paper that you can join together. -- Les B, Oregon |
#5 posted 11-07-2018 09:10 PM |
Oops. re-read the O/P, -- A bad day woodworking is still better than a good day working. |
#6 posted 11-07-2018 09:16 PM |
Taking the drawing to the local Reprographics shop which prints plans for Architects, Engineering, Land Surveyors, Contractors, or one of the above professional offices and ask them to enlarge it for you to scale. -- Woodworking, the transformation of nature to culture. |
#7 posted 11-10-2018 03:42 PM |
This is a common method. If I may elaborate a bit; I’ll make two assumptions. First, I assume that, when you say the magazine grid is 1/2”, it actually measures 1/2” as opposed to representing 1/2”. Then I’ll assume that the 1/2” magazine grid represents a 1” grid in reality. This means that the magazine grid is half size. So, in order to make the drawing actual size, draw a grid on paper with 1” squares. If it makes it easier and less confusing, number the squares the same on both grids. Now, as LesB said, where ever a line crosses the grid in the magazine, make it also cross the same grid line on your 1” grid. Once done, you will have the same drawing at full scale. Hope this helps. |
#8 posted 11-10-2018 04:01 PM |
Maybe Wandel’s big print program would help you? -- Everything is a prototype thats why its one of a kind!! |
#9 posted 11-11-2018 02:14 PM |
what bmerrill says! That would be the best and easiest way. A reprograpics shop can do the resizing and print the drawing out full size to use as patterns for cutting. I find they are relatively inexpensive as I do this frequently. -- Always remember: It is a mathematical certainty that half the people in this country are below average in intelligence! |
#10 posted 11-11-2018 02:45 PM |
newbie65 ~ what part of the world do you live in ?? . . -- there is no educational alternative to having a front row seat in the School of Hard Knocks. -- |
#11 posted 11-22-2018 11:22 PM |
http://lumberjocks.com/topics/297513 -- Richard (Ontario, CANADA) |
Forum | Topics |
Woodworking Skill Share
13138 |
Woodturning
2783 |
Woodcarving
564 |
Scrollsawing
413 |
Joinery
1869 |
Finishing
6302 |
7856 |
32533 |
CNC Woodworking
325 |
Hand Tools
6421 |
Jigs & Fixtures
1784 |
Wood & Lumber
7244 |
1613 |
Focus on the Workspace
2614 |
1266 |
Woodworking Trade & Swap
5393 |
LumberJocks.com Site Feedback
2394 |
Coffee Lounge
9626 |
