Is this low angle block plane worth keeping?
« back to Hand Tools forum
Forum topic by Dlr86 posted 11-05-2018 06:53 PM 961 views 0 times favorited 9 replies Add to Favorites Watch
View Dlr86's profile
Dlr86
2 posts in 1285 days
11-05-2018 06:53 PM
Topic tags/keywords: low angle block plane
I recently purchased a Stanley 60 1/2 low angle block plane from a recommended online vintage hand tool dealer. It wasn’t listed as having any flaws and said it didn’t have any chips or cracks around the mouth. I paid what I think is a reasonable price for a used tool in good working order screened by a knowledgeable person. However, I was pretty upset when I opened the box up and immediately saw it has a unevenly filed or ground down mouth which looks ugly. I think I could have done as well off of ebay
Being new to woodworking I am not sure what effect this will have, if any, on the function of the plane. This is meant to be a user and I don’t care about the collectability or resale value so much, but I am not sure if this is worth what I paid for it.
I have attached several photos showing the mouth opening. Otherwise it seems in good condition.
Fully closed:
Fully open:
Ground side fully closed:
I have not contacted the seller at this point pending feedback from the forum. Thanks for your help!
David
9 replies so far
View HokieKen's profile
HokieKen
11982 posts in 1740 days
#1 posted 11-05-2018 07:08 PM
Can’t really comment on whether it’s worth what you paid since I don’t know what you paid. But, I don’t see that being an issue in use.
-- Kenny, SW VA, Go Hokies!!!
View Andre's profile
Andre
2994 posts in 2407 days
#2 posted 11-05-2018 07:14 PM
Check for square to sides, with adjustable mouth you can file square on rear mouth opening as required. Flatten, smooth the bottom with some 180/220 grit sandpaper on a flat surface, I usually check to ensure sides are square at the same time. I also switched the iron to a PMV-11, while not a Veritas or LN, will work fine.
View bondogaposis's profile
bondogaposis
5604 posts in 2953 days
#3 posted 11-05-2018 07:14 PM
I looks like it has an adjustable mouth, if so you could file it straight.
-- Bondo Gaposis
View JayT's profile
JayT
6354 posts in 2812 days
#4 posted 11-05-2018 07:17 PM
If it’s just the mouth, it won’t be an issue for a user. If the bed for the blade has been filed on just that side and there is no support for that corner of the blade, it will be.
-- https://www.jtplaneworks.com - In theory, there is no difference between theory and practice. In practice, there is.
View therealSteveN's profile
therealSteveN
4589 posts in 1176 days
#5 posted 11-05-2018 08:51 PM
I wouldn’t even file it until i closed the mouth and gave it a go. If it pulls off skinny curls, use it, and go…...
-- Think safe, be safe
Dlr86
#6 posted 11-07-2018 05:55 PM
Thanks everyone for the advice. I contacted the seller with a picture of the plane and he apologized for putting the wrong description. I am keeping the plane at half the original listed price.
HokieKen
#7 posted 11-07-2018 06:18 PM
I’d say you got the good end of that deal :-)
View DBDesigns's profile
DBDesigns
232 posts in 599 days
#8 posted 11-07-2018 06:42 PM
Dear Dlr86,
I have been rescuing old planes for years now. First, I’m glad the seller was principled enough to give you some relief on the cost of the plane. A 60 1/2 is a great block plane and it will serve you well if you tune it properly.
I will say this. There are many 60 1/2 planes on EBAY and they are not very expensive. I would not have bought or sold that plane because of the damage to the throat. It looks like some ham fisted nail bender took a file to it with little consideration for results. The normal problem that occurs with this type of flaw is blade chatter against hard wood end grains.
If you can find a thicker iron for the plane that may fix the issues. You also may want o haunt EBAY for a 60 1/2 sole that is in good shape but missing other parts since you have a complete plane. Check out this guy’s store on EBAY; https://www.ebay.com/str/newhampshireplaneparts.
Good luck and enjoy.
-- I remember when Grateful wasn't Dead
DBDesigns
#9 posted 11-08-2018 09:04 PM
Found this old Knuckle Cap on Ebay. Looks like it will go for pretty cheap.
https://www.ebay.com/itm/Vintage-Stanley-No-65-Low-Angle-Block-Plane-with-Knuckle-Cap/323532598954?hash=item4b540baeaa:g:PB0AAOSwn91b3ZLQ
Probably worht bidding o.
