Resaw frustration
Forum topic by Rink posted 11-04-2018 07:55 PM 1613 views 1 time favorited 29 replies Add to Favorites Watch
View Rink's profile
Rink
157 posts in 647 days
11-04-2018 07:55 PM
Please help me figure out what I’m doing wrong!
I have a 1980’s Delta 14” band saw with a 6” riser, Carter guides and a relatively new 1/2” blade.
I’ve jointed and planed all 4 sides of boards 5-6” wide.
I’ve adjusted the blade tracking so that the gullet in the middle of the tire.
I’ve tightened the blade properly.
I’ve painstakingly adjusted the Carter guides.
I’ve adjusted for blade drift.
I’ve digitally set the fence parallel to the blade, and tightened down both ends of the Delta fence.
I’ve run small (6” long by 3” wide) test pieces through successfully, getting 3/32” all around.
I hold the board (in this case 28” long by 6” wide) tightly against the fence, pushing just with my hands and also trying with the help of one of these holding the bottom:
What I’m getting is more or less like this:
Sometimes not as bad as this, but uneven and unusable. I’ve already ruined a number of boards.
Any ideas as to what I’m doing wrong? Anything else I can try? Thanks.
David
29 replies so far
View hemioutlaw's profile
hemioutlaw
4 posts in 450 days
#1 posted 11-04-2018 08:39 PM
New here and far far far from an expert but I believe that you are ripping with the grain which is causing it to seperate. I believe a planer is the tool that should be used for what you are trying to do.
Again, I’m no expert, just my two cents.
-- Twenty years from now you will be more disappointed by the things you didn't do than by the ones you did.
View Wildwood's profile
Wildwood
2794 posts in 2744 days
#2 posted 11-04-2018 08:44 PM
JMHO, not sure it’s fault of the saw or blade, think you are trying to cut case harden wood or wood that was improperly dried.
-- Bill
View Andybb's profile
Andybb
2392 posts in 1213 days
#3 posted 11-04-2018 08:46 PM
There is no shortage of posts here regarding resaw frustrations.
First question…Did you follow the Holy Grail of BS setup a la Alex Snodgrass? That is absolutely step # 1.
You said you “digitally” set the fence parallel to the blade, and tightened down both ends of the Delta fence. First thing I notice from your picture is that there is a gap at the top of your fence/board and none at the bottom so the fence/board does not appear square to the blade.
Is the table square to the blade? If so, is the fence square to the table?
IS THE BLADE SHARP?? If so a 1/2” blade may not be rigid enough for the job. If you have at least a 14” saw maybe try a 3/4” blade?
You say you have tightened the blade properly. What are you using to determine this?
Are you cutting thin veneer? If so, are you slicing to the inside or the outside of the blade? I’d suggest leaving the cutoff to the outside using something similar to these jigs.
The BS is probably the hardest tool to setup IMO. A LOT of moving parts and adjustments that are all related to each other.
I ve adjusted the blade tracking so that the gullet in the middle of the tire.
- Rink
Try centering the blade, not the gullet then adjust for any drift. Some saws behave better that way.
-- Andy - Seattle USA
View northwoodsman's profile
northwoodsman
260 posts in 4356 days
#4 posted 11-04-2018 08:49 PM
Before you give up try a new blade. I have a Laguna carbide tipped blade and I can consistently cut 1/16” slices all day long without hardly any effort. I had some cuts that looked like yours with a bad blade. The teeth on one side of the blade hit a guard when I forgot to tension the blade so the teeth on one side were dull while on the other side sharp and it would wander all over the place no matter what I did. Don’t go cheap on the blades, buy the best you can find or you will have a big, expensive machine that will just take up space and collect dust. You don’t have to go to carbide ($$$) to get a good blade but WOW, what a difference.
-- NorthWoodsMan
View shampeon's profile
shampeon
1900 posts in 2793 days
#5 posted 11-04-2018 09:12 PM
You’re trying to do veneers, I guess? Assuming that your saw is perfectly set up a la Snodgrass, I agree that your blade is probably the culprit. That, and you’re pushing your saw beyond it’s capabilities for veneer work. Go slightly thicker to accommodate the kerf of your blade.
View Jim Finn's profile
Jim Finn
2782 posts in 3531 days
#6 posted 11-04-2018 09:27 PM
The fact that you have any drift shows you do not have a sharp blade.
-- No PHD just a DD214 Lubbock Texas
View TheFridge's profile
TheFridge
10859 posts in 2095 days
#7 posted 11-04-2018 09:35 PM
Set the guides as close to the work as you can as well.
View Robert's profile
Robert
3602 posts in 2090 days
#8 posted 11-04-2018 10:38 PM
Few questions and a couple comments.
Sounds like you’ve done everything right.
What do you mean by “tighten the blade properly”? I hope you’re not using the gauge. I suggest tighten the dog doo doo out of it. If you’re worried about too much tension, don’t be. You can’t over tighten a 1/2” blade on a 14” bandsaw.
Second, forget about chasing down the “holy grail” hat was mentioned (gotta laugh at that) because what a lot of people apparently don’t know is Snodgrass’s tune up doesn’t work on every bandsaw.
My suggestion is track the blade in the middle, readjust your guides and see if that helps. With the Snodgrass “gullet in the middle” sounds good, but some saws the blade may be tracking off center when you put pressure on it. Crowned tires are intended ot have the middle of the blade ride on the center of the crown.
What kind of blade are you using and how new is it?
A dull and/or too loose blade will belly out and/or follow the grain maybe this is what’s happening.
Andybb
#9 posted 11-04-2018 10:57 PM
Second, forget about chasing down the “holy grail” hat was mentioned (gotta laugh at that) because what a lot of people apparently don t know is Snodgrass s tune up doesn t work on every bandsaw.
A dull and/or too loose blade will belly out and/or follow the grain maybe this is what s happening.
- rwe2156
I just think the “holy grail” is a place to start if you’re starting from scratch which is why I suggested that you track your blade in the middle vs the gullet like Snodgrass says. That is also why I asked about what method he was using to decide on proper blade tension and asked if the blade was sharp so I think we’re kinda saying the same thing. He needs a baseline to start from and Snodgrass is that baseline IMO. Good luck with it.
View Knockonit's profile
Knockonit
642 posts in 811 days
#10 posted 11-04-2018 11:07 PM
rink, I sure know your frustration, i too struggled thru the resaw goal, tuned, and re tuned, new guides, urethane tires, blades ect. but not till i purchased a good brand name blade did i find success. and now with my 20 inch delta, i just got some blades from highland and well the 3/4 cuts like budda. I also have a 3/4 on my 14 inch, from olson, does ok, no complaints,
trick is don’t give up, when you feel the end is near and the big fing hammer is gonna come out to educate the saw, it all comes together
best of luck Rj in az
-- Living the dream
View msinc's profile
msinc
567 posts in 1113 days
#11 posted 11-05-2018 12:51 AM
I have a two year old PM1500 saw. The only time I am able to cut a nice re-saw is when the blade is razor sharp {which typically isn’t very long}. The only time I cannot cut a good re-saw and have trouble is when the blade is dull. It doesn’t take much use for these new band saw blades to quickly get too dull to perform re-saw work. Little nit pickety adjustments, tensions, etc. have never stopped me from getting usable re-saws. Adjustments don’t have to be dead on to re-saw, but they have to be within reasonable close. Yours sound way better than that. Only a bad blade will ruin the work. When I say “bad” blade, I mean bad for use re-sawing, I do not mean bad for band sawing in general use.
Any blade that has any amount of time on it, even if it was treated perfectly and always kept in perfect adjustment will just not do when we are talking re-saw. The blade that has been on your saw for a while and still works just fine for general band saw work WILL NOT GET IT when it comes to re-sawing.
As posted, buy a carbide blade if you intend to do much of any re-saw work, it is cost effective in the long run. When you figure out that you pretty much need a new blade every time you need to re-saw some wood all of a sudden the cost of a good carbide re-saw blade will make sense.
You can fight it playing with adjustments…I have seen guys replace everything up to the entire saw, but what ultimately solved the problem was always a razor sharp, new blade. Best of luck.
View Rink's profile
Rink
#12 posted 11-05-2018 03:44 AM
Okay, the consensus seems to be that the blade is a very good candidate for being the problem. I don’t have time tonight to try a new blade, but I’ll report back when I do.
What I have on the saw right now is a Kerfmaster Blade from Spectrum Supply. I don’t remember how I got to them, but they seem reputable.
The one I’ve been using to try to resaw is 105”, 1/2” wide, 0.22” thick, and “Vari-tooth standard set 3/4”.
I’ll take that one off and put on a new, unused 105”, 5/8” wide, 0.16” thick, and “Vari-tooth standard set 3/4”.
Crossing my fingers that hat solves the problem. If it does, and then if it gets dull quickly, I’ll look into a carbide blade.
David
View DrDirt's profile
DrDirt
4600 posts in 4351 days
#13 posted 11-05-2018 04:33 AM
The issue to me is going to be as follows –
I have a ~2001 Delta 14 inch saw with the 6 inch riser block, running 1/2 inch wide 3 tpi 105 inch blades.
I have not changed to Carter guides, but do use “Cool BLocks” to guide the blade, and the old style thrust bearing mounted 90 degrees to the blade.
First thing I would look to is a sort of featherboard to keep the bottom tucked in – - I have a magnetic one. Challenge is always that you are watching the top edge being cut, but keeping the bottom tight to the fence is difficult, especially cutting for 2-3 feet…suspec the “blown out” section in your pic is at the bottom.
Thrust bearing spacing – WHen you are ‘Pushing”... are you inducing deflection
which goes hand in hand with Blade Tension
Sharpness of the blade
Finally
Cutting speed. You are cutting through and moving a lot of chips…something like 1/2 per second…even through by feel the blade will cut much faster – - the cut will be rough, and the blade will want to barrel.
I would try cutting thicker first – get a 6 inch wide board that is say 1/2 inch thick – and try to ‘Split it down the middle.
work your way down to cutting 1/8 strips. They will need surface prep anyway, .like drum sanding at that thickness… you can’t really run 3/32 through a planer to get to 1/16.
View therealSteveN's profile
therealSteveN
4655 posts in 1183 days
#14 posted 11-05-2018 04:53 AM
I ll take that one off and put on a new, unused 105”, 5/8” wide, 0.16” thick, and “Vari-tooth standard set 3/4”.
David
- Rink
David I am not sure what you are saying there? Is it a 5/8” blade, or a 3/4” blade? Do you mean 3 to 4 tooth per inch?
3/4” WILL NOT play well on that saw, your tires are crowned, and that area will support at best a 1/2” blade. For resaw you want the fewest teeth possible. Your best bet until you get a better feel for this is sawing slower and use a 3/8” blade and cinch that puppy down till you can play it like a guitar, forget that tension gauge.
Seriously you want it tight so pushing in on the blade will only deflect inward 1/4” MAX. Anything sloppier than that will allow wander, and drift. You won’t get good cuts. Tight is right, loose is $#!+
You might want to put in a location on your profile, City and State are more than adequate. Could be a guy lives 1/2 mile away, that could show you what many are saying here.
-- Think safe, be safe
therealSteveN
#15 posted 11-05-2018 05:05 AM
Thrust bearing spacing – WHen you are Pushing”... are you inducing deflection
Finally
I would try cutting thicker first – get a 6 inch wide board that is say 1/2 inch thick – and try to Split it down the middle.
work your way down to cutting 1/8 strips. They will need surface prep anyway, .like drum sanding at that thickness… you can t really run 3/32 through a planer to get to 1/16.
- DrDirt
YES
Tall fence to give solid support to the left of the blade. If you are resawing 12” have at least a 10” tall fence. Make that fence square, straight, flat, and true. Something at right angles so you can firmly clamp it to your table.
Then YES again, a featherboard to keep the board from drifting off the blade. Those mag switch suckers are worth every penny. Slap em anywhere, and turn that dial. Frozen in place.
Something I am not sure if anyone said, and I do it, but usually never think to say it….....
You can do all of these things, and still get squat if that board is rough, and isn’t dead flat on the side facing the fence. Trying to run a cupped, twisted, crappy board against the fence will get you 2 crappy boards. You MUST face joint, or plane that reference face/edge on every pass. No jointer or planer, you will need to buy S4S stock, or have a buddy process it for you.
showing 1 through 15 of 29 replies
