Proper MDF Application
Forum topic by Joe posted 11-04-2018 01:04 PM 538 views 0 times favorited 6 replies Add to Favorites Watch
View Joe's profile
Joe
24 posts in 3612 days
11-04-2018 01:04 PM
Topic tags/keywords: mdf humidity heat swelling
Hello All,
I’m building my first project with MDF and now that it’s finished and ready for paint I have a concern. I built a radiator cover for a steam radiator and now I’m wondering how compatible the MDF is going to be with the slight amount of moisture that escapes from the radiator vent. I was planning to give it a couple of coats of de-waxed shellac before the color coat for protection. Is this a good use for the MDF?
-- Joe
View BFamous's profile
BFamous
344 posts in 1041 days
#1 posted 11-04-2018 01:35 PM
MDF is going to move less (aka not at all) than normal wood due to the changes in humidity. As long as it is sealed properly so that the fibers do not get wet from the moisture, which would cause them to swell, you should be fine in my opinion…
-- Brian Famous :: Charlotte, NC :: http://www.FamousArtisan.com
View Lazyman's profile
Lazyman
5974 posts in 2308 days
#2 posted 11-04-2018 02:18 PM
Perhaps you used a formaldehyde free MDF but I would be more worried about formaldehyde or other VOCs being released into the room when it heats up. I would certainly not want to take the risk, especially if you have kids.
View Bill White's profile
Bill White
5312 posts in 4881 days
#3 posted 11-04-2018 02:44 PM
I have posted several times about my use of a moisture resistant MDF product called Extera. Very stable, and used for exterior applications. May not be easily available, but sure is good stuff for jigs needing to last for a long time. Might be the product that you need.
-- [email protected]
View jmos's profile
jmos
917 posts in 3290 days
#4 posted 11-04-2018 02:48 PM
I think it was the last Fine Woodworking podcast (or a recent one in any event) where they were discussing that MDF does move with moisture. The comment was made in the context of most folks not knowing this. Surprised me.
I don’t use it much, so couldn’t say for sure.
-- John
View lumbering_on's profile
lumbering_on
578 posts in 1410 days
#5 posted 11-04-2018 03:10 PM
I don t use it much, so couldn t say for sure.
- jmos
Yes, MDF does expand and contract, but it does it in a uniform fashion. I found this out when I installed some wainscotting I made out of 1/2” MDF. It meant I spent a fair bit of time going back and touching it up, but it’s still better than using pine.
View oldnovice's profile
oldnovice
7683 posts in 4288 days
#6 posted 11-04-2018 06:17 PM
I know that MDF swells with moisture, so if that is movement, it does move!
-- "It's fine in practise but it will never work in theory"
