Dust collector motor swap?
Forum topic by Tzweber posted 11-04-2018 01:51 AM 446 views 0 times favorited 8 replies Add to Favorites Watch
View Tzweber's profile
Tzweber
46 posts in 487 days
11-04-2018 01:51 AM
Topic tags/keywords: dust collector question shop
I was lucky enough to pick up a 5hp torit dust collector today for about the price of a 1.5hp roll about unit. One problem. It has a 3 phase motor. What would you all do? Options I’ve found so far are; buy a new 1 phase baldor motor ($550-1000), buy a 15hp rotary phase ($1000-1500) or hope a used motor comes into my local motor rebuild shop.
8 replies so far
View shampeon's profile
shampeon
1900 posts in 2791 days
#1 posted 11-04-2018 02:24 AM
Buy a VFD. $100-400.
Tzweber
#2 posted 11-04-2018 03:21 AM
Where do you find a VFD capable of sending 20amps at 220v for that price?
View FancyShoes's profile
FancyShoes
592 posts in 1972 days
#3 posted 11-04-2018 04:11 AM
I fond it funny how so many people are quick to say VFD.. bro, not every machines needs a variable speed! Peope see like, put vfd on that table saw… why not spend less and use a static phase convertor?
I would say sell it and but another one that is single phase.
What is the RPM of your motor? I have a few spare 5hp motors, I could let one go for $250, they are 3450 rpm
Tzweber
#4 posted 11-04-2018 12:46 PM
The motor I need to replace is a 184TC frame 3450 rpm Baldor motor. I’d take one off your hands if you’re willing and not too far away to ship for a reasonable price.
shampeon
#5 posted 11-04-2018 04:29 PM
Ebay has a bunch of varying quality. I’d probably steer clear of the cheapest ones, though some people have been running them with no trouble.
Static phase converters are harder on the windings and lose a third of the HP, but they’re cheap and simple, it’s true. But why turn your 5 HP into a 3.3HP motor?
The reason you get a VFD isn’t necessarily because you want to vary the speed of the motor, it’s because you get full HP in a 3ph motor using 1ph wiring, all for less than the cost of replacing it with a new 1ph motor. Variable speed is a bonus feature you can use or not.
MrUnix
7597 posts in 2807 days
#6 posted 11-04-2018 07:50 PM
- Tzweber
Is the 5hp motor on yours really rated at 20A?!?
- FancyShoes
That would be my absolute last resort, and I’d rather swap motors than go that route. As mentioned, the SPC will reduce the motors power by roughly 1/3, and run the motor unbalanced – causing it to run hot and therefore more likely to burn up prematurely. Both conditions make it an extremely bad choice for a DC.
Tzweber
#7 posted 11-04-2018 08:45 PM
19.6 amp at 100% load. Starting amps is considerably higher to get the thing to spin up. That’s why it’s wisely suggested to get 2.4X the hp rating when selecting a rotary converter. Industrial products don’t mess around with posting high fake hp numbers but low FLA numbers.
Tzweber
#8 posted 11-04-2018 08:52 PM
I should also mention the motor is not rated for inverter duty so that really limits VFD choices although it doesn’t rule them out completely.
