Table saw issue - need advice
Forum topic by Mags3290 posted 11-03-2018 03:51 PM 444 views 0 times favorited 5 replies Add to Favorites Watch
View Mags3290's profile
Mags3290
14 posts in 756 days
11-03-2018 03:51 PM
Topic tags/keywords: tablesaw
Here’s another delta 36-725 post.. I’ve reached around and haven’t been able to find a situation like mine. If there is a post please point it out.
In September I upgraded my dewalt dwe7480 to a delta 36-725. I was able to get the saw set up and tuned with no problems. I did notice a slight bow in the table, whch based on the posts I’ve read is a pretty common thing. I did a few shop projects the saw performed well.
Im gearing up to get some holiday projects done. So i went though the process of checking the tuning again and I noticed the blade was out .012 to the right and when I tuned it the first time it was not like this. Im a newbie so I’m not sure if this is a normal occurance? I don’t think I should have to re-tune the saw that often. I’m not sure if I should chalk.this up to this being a $600 saw and you get what you pay for.
Anyway this has got me thinking and I’m considering just sending the saw back to Lowe’s. And spending a bit more on the grizzly hybrid or sawstop contractor saw.
I was hoping I could get some input from some people in the forum as I’m not quite sure what to do. Thanks in advance.
5 replies so far
View Ripper70's profile
Ripper70
1368 posts in 1510 days
#1 posted 11-03-2018 04:16 PM
Well, I can’t tell you how to fix your Delta alignment issues but if returning the saw and replacing it with the Grizzly G0771 is an option, I’d go that route. Cabinet mounted trunnions, a 2 hp motor, riving knife and increased mass make it a more attractive choice in my book.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View knotscott's profile
knotscott
8351 posts in 3977 days
#2 posted 11-03-2018 05:02 PM
”...the blade was out .0012…”
That’s 1.2 thousandths of an inch….decimal dust, and hard to even measure accurately. I’d celebrate the day that a deviation like that was my biggest concern.
With that said, your other two options would likely be upgrades to some degree.
View EdDantes's profile
EdDantes
74 posts in 512 days
#3 posted 11-03-2018 05:22 PM
Agree…getting blade to miter slot parallelism to less than 0.003” is acceptable. And really, it may not even be noticeable until you start getting above 0.005”. If you had it closer than 0.0012 when you got it and are concerned it’s moved over 2 months of use, I wouldn’t be. That’s the way it’s probably going to be with most contractor or hybrid saws. Regularly checking and adjusting alignment is one of the tradeoffs. If you’re looking for something that’s going to hold alignments longer, I’m not sure your alternatives are going to be huge upgrades. The Grizzly may be slightly better and the cabinet mounted trunions may make it easier to adjust, but the real solution is getting a true cabinet saw.
If you’re keeping the Delta, I’d suggest looking into Contractor Saw PALS which will make adjusting the alignment with table mounted trunions easier. I’ve also found they help hold the alignment a bit longer.
Mags3290
#4 posted 11-03-2018 05:38 PM
EDIT. TYPO I added an extra 0. The blade is .012 off
I will check out the PALS thanks!
Agree…getting blade to miter slot parallelism to less than 0.003” is acceptable. And really, it may not even be noticeable until you start getting above 0.005”. If you had it closer than 0.0012 when you got it and are concerned it s moved over 2 months of use, I wouldn t be. That s the way it s probably going to be with most contractor or hybrid saws. Regularly checking and adjusting alignment is one of the tradeoffs. If you re looking for something that s going to hold alignments longer, I m not sure your alternatives are going to be huge upgrades. The Grizzly may be slightly better and the cabinet mounted trunions may make it easier to adjust, but the real solution is getting a true cabinet saw.
If you re keeping the Delta, I d suggest looking into Contractor Saw PALS which will make adjusting the alignment with table mounted trunions easier. I ve also found they help hold the alignment a bit longer.
- EdDantes
EdDantes
#5 posted 11-03-2018 05:53 PM
Ah, ok. Well yes…that needs to be adjusted. What was it when you first got it?
Even still, I wouldn’t be surprised by a contractor saw needing intermittent re-alignment. And while the degree/frequency may be different with those other options, it’s not going to be eliminated.
