Glue removal tip wanted...
Forum topic by jutsFL posted 11-03-2018 03:41 PM 1037 views 0 times favorited 54 replies Add to Favorites Watch
View jutsFL's profile
jutsFL
192 posts in 442 days
11-03-2018 03:41 PM
Topic tags/keywords: glue removal
Hi everyone!
Ive got the excesive dried glue problem with my walnut panel. Normally (as I am a new woodworker) id just go to town with my RO sander. I’m hoping that someone has a tip on how to (easily?) remove the excess from the joint areas before the real sanding begins. Maybe a scraper on the areas, or would a carefully used solvent work?
Open to any ideas. This will be the top of a coffee table.
-Jay
-- I've quickly learned that being a woodworker isn't about making flawless work, rather it's fixing all the mistakes you made so that it appears flawless to others! Jay - FL
54 replies so far
View AlaskaGuy's profile
AlaskaGuy
5516 posts in 2910 days
#1 posted 11-03-2018 03:55 PM
You answered you own question. Card scraper. Also a good way to fix any minor miss alignments between boards.
https://youtu.be/PM-5WPl63wc
jutsFL
#2 posted 11-03-2018 04:25 PM
Thank you!
Being new, like a year in new, I dont even know the real names of the tools to know what to search for.
...is a card scraper of any functional difference than the handled paint scrapers I already own?
Smitty_Cabinetshop
16319 posts in 3219 days
#3 posted 11-03-2018 04:28 PM
Card scraper, paint scraper, either can work if shaped and sharpened properly. Yes, scrape before sanding is a great approach.
View Andybb's profile
Andybb
2334 posts in 1204 days
#4 posted 11-03-2018 04:52 PM
Card/cabinet scraper videos
-- Andy - Seattle USA
View Rich's profile (online now)
Rich
5126 posts in 1190 days
#5 posted 11-03-2018 05:13 PM
I like to wait until the glue has just dried and you don’t see any wet glue down in the center of the bead and then slice it off with a chisel plane. It’s important not to wait until it’s fully hardened though. A stiff putty knife with a chisel edge will work too.
View Andre's profile
Andre
2986 posts in 2407 days
#6 posted 11-03-2018 05:16 PM
I have a lot of old plane blades after switching all my Stanley’s to PMV-11 irons and found the old irons make excellent glue scrappers.
View GR8HUNTER's profile
GR8HUNTER
6797 posts in 1313 days
#7 posted 11-03-2018 05:26 PM
after first hour …. use your paint scraper then….. so it will easily come off :<))
jutsFL
#8 posted 11-03-2018 05:46 PM
I just had the time to watch the first linked video, this is beautiful! Absolutely perfect , and exactly what I needed – thanks AlaskaGuy, and everyone for that matter.
...with the glue up I used (face referenced my dining table for flatness) I could not get to the glue on the face as it dried to scrape ahead of time. Live and learn I suppose.
View Richard's profile
Richard
11309 posts in 3634 days
#9 posted 11-03-2018 09:26 PM
I have a lot of old plane blades after switching all my Stanley s to PMV-11 irons and found the old irons make excellent glue scrappers.
- Andre
Andre +1 Great Idea
Rick S.
-- Richard (Ontario, CANADA)
View Kazooman's profile (online now)
Kazooman
1408 posts in 2553 days
#10 posted 11-03-2018 09:56 PM
- jutsFL
Yeh, that is the nature of the beast. I would imagine that you had some sort of plastic down to protect the table and the squeeze out got spread out pretty thin between the piece and the plastic.
First, a “great idea” commendation for using your dining room table as an assembly table. Second, a “most understanding spouse” commendation (if you are married) to whoever actually allowed you to do this. My wife is very understanding and supportive, but trust me, there ain’t no glue-ups happening on our dining room table!
The good news is that the squeeze out looks pretty limited and thin. I have found that if I get everything in place, lightly draw up the clamps, then tighten up a bit on the cauls before the final clamping pressure is applied most of the squeeze out is directed upwards (at least it seems that way). I do tend to use more cauls on a piece that size.
jutsFL
#11 posted 11-04-2018 12:24 AM
- jutsFL
First, a “great idea” commendation for using your dining room table as an assembly table. Second, a “most understanding spouse” commendation (if you are married) to whoever actually allowed you to do this. My wife is very understanding and supportive, but trust me, there ain t no glue-ups happening on our dining room table!
- Kazooman
The dining table reference worked very well for the flatness of the panel… But had obvious shortcomings :)
...and, yes, my wife is wildly leniant with the stuff I get away with from this borderline obsession with woodworking. Not only was I able to use the table, but it remained there overnight – with my mother in law visiting at the time !
Appreciate the tip as well. Ive noticed very quickly from the gentleman I buy my lumber from in town – 10sec worth if a mans thoughts thats been doing this for a lifetime, is equivelent to roughly 7 days of profanity filled blunders in the garage :)
View chrisstef's profile
chrisstef
18021 posts in 3607 days
#12 posted 11-04-2018 12:49 AM
Fwiw i keep a deck of playing cards in the shop to use on squeeze out. Theyre stiff enough to run right along the joint with a lil curl to em to keep the wet glue on top of.
View shipwright's profile
shipwright
8452 posts in 3399 days
#13 posted 11-04-2018 03:34 PM
........... or you could use hide glues and clean up with water.
Just sayin’
Rich
#14 posted 11-04-2018 04:15 PM
Just sayin
- shipwright
Glad you mentioned this. Besides easy cleanup, it can save your butt sometimes as well. Once I glued the dovetailed sides of a drawer to the front only later realizing I’d forgotten to cut the grooves for the drawer bottom. With PVA, I’d have had to scrap it and start over, but having used hide glue, I was able to separate the parts in about 10 minutes with a moist cloth and heat gun. Cleaning the joints for re-gluing was easy too.
AlaskaGuy
#15 posted 11-04-2018 04:21 PM
I have ask this before but no one ever answers. What is the open time of Hide Glue. Can it be varied. Right now I have the impression hide glue give you abut a minute of open time. Such a short open time seems problematic.
showing 1 through 15 of 54 replies
