Forum topic by Italo78 | posted 11-03-2018 05:28 AM | 25023 views | 1 time favorited | 28 replies | ![]() |
Topic tags/keywords: cad software solidworks nx autocad sketchup revit inventor woodworkers furniture Cheers to all, What is the best software for woodworkers? Thanks for taking a look! - Windy City Tony |
28 replies so far
#1 posted 11-03-2018 06:17 AM |
I use Autocad Architectural Desktop, and I have a degree in Architectural Engineering and that’s probably why I use CAD since I already know it. Our commercial millwork shop now uses Microvellum (extremely expensive and takes much training in it) along with Autocad Architectural Desktop. If you’re looking for 3d then I think most woodworkers are using Sketchup. Sketchup is an awesome 3d program and well worth learning if you’re a woodworker designing your own personal stuff. Sketchup has a large learning community. I have a friend that’s an Architect using Sketchup Pro and is doing some awesome 3d work in it. -- Bruce Free Plans https://traditionalwoodworking.org |
#2 posted 11-03-2018 01:13 PM |
I use the free version DraftSight, it is very similar to AutoCAD. -- Bondo Gaposis |
#3 posted 11-03-2018 05:19 PM |
I use a Mac computer so I chose Microspots, Mac Draft Pro for my 2D drawings. -- Les B, Oregon |
#4 posted 11-04-2018 12:55 AM |
What is the type of cad drawing you want to do, 2D or 3D? 3D is fine for “concept” drawings, but 2D is better for details. If I were machining a part on a milling machine or lathe, I would use a 2D drawing. I use Autocad for all my 2D drawings and have not seen a need for 3D. I prefer Autocad (mainly because that’s what I learned) and I can use it in any type of drawing; structural, architectural, woodworking, plumbing, electrical. It is a very versatile software. It is a very expensive software, but you can get it free (as a student) as long as you don’t use it for profit. |
#5 posted 11-04-2018 01:33 AM |
I’ve made the move to Fusion 360 as you can get it for free as a hobbyist. I was using Sketchup, but I didn’t like the move to the web-based version. I also found that after the switch to Fusion 360 a lot of things are much easier than they were in Sketchup. In fact, I now find Sketchup down right clumsy and frustrating to use. |
#6 posted 11-04-2018 01:43 AM |
I have SketchUp Pro and it does everything I need. Combined with a rendering package I can show my clients exactly what they will get. -- Half of what we read or hear about finishing is right. We just don’t know which half! — Bob Flexner |
#7 posted 11-06-2018 04:05 PM |
Glad this question was asked. I am also an AutoCAD guy, but prefer not to pay the price for it. I haven’t had the need for a detailed CAD program for design needs as I mostly can do that by hand (quick drawing with dims). What I need it for is to show the customer the design (3D) so I was trying out Sketchup, but like lumbering_on said it is clumsy. I might try Fusion 360 that he/she suggested. |
#8 posted 11-06-2018 07:58 PM |
I’ve used Pro Engineer extensively for years (now called Creo), which is one of the most widely used engineering packages. I have also used Mechanical Desktop and to a lesser degree Inventor, and Solidworks (very little). I did production design using Autocad AME in Release 12… took all night to generate ISO views, running a single view per Pentium workstation… Creo is expensive and probably overkill for most woodworkers but they now offer “pay as you go” service; they also allow a one month free trial version, which you can extend the use of by changing the date on your computer prior to running it. Just mentioned it since, IMO, if you’re going to invest your time in the learning curve you might as well hit the broadest market. I also did a long term live review of Catia V6 just after it was introduced, I wouldn’t have a copy of that if it was free. That was several years ago, it might have matured in the interim but it was a (bad) joke back then. I have used 2D Autocad since x286 processors and can verify that Draftsight is functionally an exact replica and is free, assuming you can get their goofy e-mail verification to work. There are ways to make it work if it doesn’t after downloading and well worth it considering the price of Autocad. It even uses the single & double-digit hotkeys from Autocad (“L” for Line, “E” for erase, etc.) even when their command has a different name (Erase is actually Delete in Draftsight). |
#9 posted 11-12-2018 04:04 PM |
Thanks to everyone for taking time out of your day to reply to my question. Thanks again to everyone for your time. -Tony |
#10 posted 01-08-2019 10:03 AM |
Have you looked into Woodwork for inventor? It works with Inventor so it’s not cheapest on the market. Nevertheless, it saves an incredible amount of time by automating BOM, drawings and many other specification generations. |
#11 posted 01-08-2019 11:18 AM |
SketchUp for me. Simple, powerful, massive library of components already available. |
#12 posted 07-16-2019 07:01 PM |
I know this is an old post but does somebody have an update recommendation, preferably 3D? I did some searching and was interested in Fusion 360 but it is no longer free to hobbyists and is only available as a subscription. I was looking for some thing easy and free (or cheap) that specifically had woodworking features, and preferably with a good following to help in learning the program. -- DannyW |
#13 posted 07-17-2019 05:34 PM |
Fusion 360 is still free for hobbyists. They make you jump through some hurdles, but its there. I use both Fusion 360 and SketchUp. Both have their strengths and weaknesses. |
#14 posted 07-17-2019 10:05 PM |
I’m a hobbyist and have been using SketchUp to design my woodworking projects for over 10 years. Now that I’m an employee I get SketchUp Pro for free but before that I used “Make” which is the free version of “Pro”. SketchUp Make 2017 is still available for free from https://www.sketchup.com/download/all SketchUp is easy to use but I think it really helps to have someone show you the basics when you’re getting started. There’s a ton of free training available on youtube and other places on the web. I also think our in-house training materials are excellent at https://learn.sketchup.com/ If you’d rather use the free web version you can find that at https://app.sketchup.com |
#15 posted 07-18-2019 07:29 PM |
I have been looking at video tutorials on both Sketchup and Fusion 360 from a woodworker’s standpoint. Both will require a learning curve but so far I like what I see in Fusion 360 far better; I like the parametric focus as it looks like building components will be much easier and more versatile once I get the hang of it. Thanks for the note about it still being free for hobbyists. -- DannyW |
Forum | Topics |
Woodworking Skill Share
13136 |
Woodturning
2783 |
Woodcarving
564 |
Scrollsawing
413 |
Joinery
1869 |
Finishing
6302 |
7855 |
32533 |
CNC Woodworking
325 |
Hand Tools
6421 |
Jigs & Fixtures
1784 |
Wood & Lumber
7244 |
1613 |
Focus on the Workspace
2614 |
1266 |
Woodworking Trade & Swap
5393 |
LumberJocks.com Site Feedback
2394 |
Coffee Lounge
9626 |
