10" Craftsman Band Saw: Capabilities?
Forum topic by MSquared posted 11-02-2018 08:44 PM 379 views 0 times favorited 6 replies Add to Favorites Watch
View MSquared's profile
MSquared
965 posts in 522 days
11-02-2018 08:44 PM
Hi all. I have a 1980’s 10” Craftsman Band Saw. I haven’t touched in ages. Just getting into some ‘serious’ woodworking (which translates into ‘basic woodworking’ to very many here). What are it’s capabilities? Re-sawing? Rough shaping? Layered piece cutting? How thick? Let’s start with ; “I know nothing” and go from there. Thanks!
-- Marty, Long Island, NY
View OSU55's profile
OSU55
2507 posts in 2598 days
#1 posted 11-02-2018 10:18 PM
See if the one in this review is similar. If so its an excellent saw just limited in resaw and throat depth. Great to keep around for work that fits.
View shampeon's profile
shampeon
1900 posts in 2792 days
#2 posted 11-03-2018 12:34 AM
^^ If it’s from the 1980s I don’t think it’s that one, which is a rebadged Rikon.
If it looks like this:
it’s a 3 wheel bandsaw, and it’s not a very good saw. You for sure can’t resaw, and tracking is really finicky. Real basic shaping of woods up to maybe 2” thick is pretty much what you’re looking at. It’s just not a tool designed for real wood working. I picked one up for $20 when I started woodworking, and I sold it almost immediately for the same amount. The 2 wheel 12” Jet I replaced it with was miles better.
Craigslist is usually filled with better 14” bandsaws for less than $200.
MSquared
#3 posted 11-03-2018 01:10 AM
Shampeon: Yep. It’s an apparently an older version, but virtually the same machine.( Having a hard time trying to insert a photo, new here!) But I, even as a novice wanting to get more into woodworking thought it looks a bit flimsy. Luckily, I didn’t buy it! It was left behind in the garage when we bought the house. Still, is it good for anything? You mentioned roughing out up to 2” stock possibly. Can it be useful for anything else? Suggestions? ( Ooo! That’s opening a can of worms! Sold the boat, so don’t even say it!)
OSU55; Great review BTW! The photo you posted of the Band Saw is more along the lines of what I see in accomplished woodworkers’ shops.
View bandit571's profile
bandit571
24409 posts in 3291 days
#4 posted 11-03-2018 02:12 AM
IF you do a LOT of curved work…this is a very decent saw….Used one for a LONG time. And still have it as a back up, for when the main bandsaw is down….there is 6” of room there…blade width is the main limit to these saws.
The tires on mine can be replaced by simply using the drive belts from a Dirt Devil sweeper….I paid $90 for mine..a LONG time ago. But….mine is the 12” version of that saw…and will take up to a 3/8” width blade. but, it is still a 3-wheeler. And a Royal PITA to install a new blade on….
shampeon
#5 posted 11-03-2018 02:45 AM
Well, compared to a decent bandsaw the cuts on this one will be:
  • not as square
  • not as straight
  • take longer
If you’re cutting mostly thin stock and aren’t super concerned about accuracy, it’ll work.
I mean, you’re just getting into woodworking, and it’s a tool you already have, so use it. If you stick with woodworking, you can replace it when it’s worth it to you to do so. But I wouldn’t put any money into it except a new blade.
MSquared
#6 posted 11-03-2018 04:55 AM
Ah! Thanks all! So,what I gather is, it has it’s place in the shop for now. Get used to working a band saw. Make some stuff. Surely work up to a much finer one. Stash it in the (tiny) shop loft when the shop space is needed…. That works!
