Just picked up an older 6” sears jointer looking for advice?
« back to Joinery forum
Forum topic by Dubbs posted 11-02-2018 01:50 PM 903 views 0 times favorited 5 replies Add to Favorites Watch
View Dubbs's profile
Dubbs
35 posts in 445 days
11-02-2018 01:50 PM
Topic tags/keywords: sears 6” jointer 1960 antique question
Just picked this up. Some of the labels for measurements are worn away. Anyone know where to get new ones?
-- —— Bruce Hicks ——-
5 replies so far
View TechTeacher04's profile
TechTeacher04
418 posts in 2135 days
#1 posted 11-02-2018 04:17 PM
you will likely have a hard time finding parts for a Sears unit of that age. What measurements do you need? as long as the bearings are good, blades are sharp, tables are in the same plane and the fence is perpendicular to the table you are in good shape.
Dubbs
#2 posted 11-02-2018 05:13 PM
That’s true. When I ran a test piece through it the first time it got hung up on the exit side of the table? Maybe it was set too deep? Not sure I’m new to this.
View Gene Howe's profile
Gene Howe
11996 posts in 4032 days
#3 posted 11-02-2018 05:33 PM
- Dubbs
More likely, the infeed was set way too low.
You might also need to adjust the outfeed table as well. I owned a slightly newer one and found that adjusting that outfeed table was a bear. But, it may need it.
View SAndelin's profile
SAndelin
11 posts in 3575 days
#4 posted 11-02-2018 07:25 PM
I have that exact model jointer on a home-made base. Found it on the local classifieds about ten years ago. I too wanted to spiff up that ruler thing with some stick-on ruler tape from the internet, but in a decade I’ve never needed it. I think if you were doing a lot of rabbet cuts on the joiner it would come in handy though. I put in some fresh blades, added some HVAC plumbing parts to the bottom to connect to the dust collection, made sure the fence was square to the outfeed table and have not touched anything other than the blades since.
-- Luck, the point where preparation meets opportunity.
View Aj2's profile
Aj2
2648 posts in 2401 days
#5 posted 11-02-2018 08:36 PM
Some of those Craftsman jointers have a fixed outfeed. That pretty much makes it a boat Anchor if you can move the outfeed then you might have a decent machine. If the tables are in alinement and flat.
-- Aj
