making magenta scroll saw pattern
« back to Scrollsawing forum
Forum topic by daddydave posted 11-02-2018 01:27 PM 883 views 0 times favorited 4 replies Add to Favorites Watch
View daddydave's profile
daddydave
15 posts in 1324 days
11-02-2018 01:27 PM
Finally discovered how to change a black pattern to magenta in order to see contrast with the blade.
1. scan black pattern and save as JPG file.
2. Upload into Inkscape (free program)
3. OPEN pattern to screen and select it (boxes pattern with X’s), select Filters, select colors then select extract channel
4. pick Magenta, Select view item box and select apply. At this point you should have a magenta pattern.
5. In file select print and there you are.
-- Dave, Cleveland, Tn.
daddydave
#1 posted 04-15-2019 02:18 PM
+My 1 hp dust collector is 75 decibels. If I enclosed it with a framing of acoustical ceiling tile with a noise absorption of .5 (along with exhaust venting); can I expect the rating to go down to less than 50 decibels?
daddydave
#2 posted 05-31-2020 07:52 PM
Have a growing supply of numerous types of wood scraps to use in my intarsia work. Have a limited amount of space and curious as how you all keep them separated in order to utilize their best selection for my work?
View GrumpyGolfGuy's profile
GrumpyGolfGuy
59 posts in 77 days
#3 posted 05-31-2020 08:13 PM
I use those plastic bins, one for each type of wood. I have a hard time tossing out a scrap that might work in an intarsia project in the future.
Chris
View shipwright's profile
shipwright
8562 posts in 3578 days
#4 posted 06-01-2020 12:10 AM
Good idea. I’ve been using red for mine for years. I also use Inkscape and recommend it to anyone who uses patterns for fine cutting. I do my own tracings but what you are doing works too.
