Laminating Boards for a Table Top
Forum topic by cpbuck posted 11-02-2018 01:14 PM 565 views 0 times favorited 11 replies Add to Favorites Watch
View cpbuck's profile
cpbuck
14 posts in 802 days
11-02-2018 01:14 PM
Topic tags/keywords: maple table table top breadboard bread board farmhouse
This might be a weird question but I was asked to make a table for my sister and she wants it made out of hard maple (I tried getting here to choose something different but failed). After spending some time looking at tables, she wants a table with a thicker top 1.5”+.
I am having trouble finding some good 8/4 stock to make the table out of locally but there is plenty of 4/4. Is there any problems with laminating 4/4 stock together and using that? Would I be able to flatten and thickness the laminate boards after without weird movement? What about the table top movement due to seasonal changes? Would the inconsistent movement between top/bottom boards cause cupping or twist?
The table will have bread board ends so I can hide the end grain. I have a few good 8/4 boards that I would use as the edge boards so as far as I know, nobody would ever know that the interior boards were laminated.
Just wanted to bounce this idea off of someone before I do something dumb!
11 replies so far
View Stan Shields's profile
Stan Shields
16 posts in 504 days
#1 posted 11-02-2018 01:22 PM
If your gonna put edging on all four sides seems kinda silly to laminate the top with hardwood. Make the edging any height you like, it can underhand the top by a bit or add filler strips behind the edging foe 2” or so.
-- Built guitars in my basement for many years, mistakes went into the wood stove, was rarely cold.
View Aj2's profile
Aj2
2658 posts in 2409 days
#2 posted 11-02-2018 01:55 PM
Trying to cut corners in woodworking sounds like a recipe for disaster.
-- Aj
View ocean's profile
ocean
196 posts in 1445 days
#3 posted 11-02-2018 02:02 PM
Unless your sister wants a solid maple top I would forego the bottom piece (you can’t see it unless your on the floor) for a good quality ply. This will solve / mitigate the warping problem. Edge band the sides with maple that is at least 1/4” wider than table is thick and use a sliding dove tails for both ends. The material cost saving – good sales point to your sister.
-- Bob, FL Keys
View bilyo's profile
bilyo
963 posts in 1714 days
#4 posted 11-02-2018 02:13 PM
I agree with Stancin. Thicken just the edges. It will save wood, save weight, and eliminate the potential problems with wood movement you mention (even though I think they would be minimal).
In order to hide the joint line at the thickened edge, you might consider using a miter cut. That way the joint will be masked by the corner.
View Dustin's profile
Dustin
707 posts in 1352 days
#5 posted 11-02-2018 02:31 PM
https://www.woodworkingnetwork.com/custom-woodworking/gluing-pressing-adhesives/How-To-Make-A-Thick-Countertop-Out-Of-Thin-Wood--249194161.html
I used this approach (I believe what bilyo is referencing above) to make a seemingly thicker table top for a welcome desk at my church. It worked great, and is still holding up terrifically after a year of use.
-- "Ladies, if your husband says he'll get to it, he'll get to it. No need to remind him about it every 6 months."
View Bill_Steele's profile
Bill_Steele
636 posts in 2343 days
#6 posted 11-02-2018 02:34 PM
I don’t think there is any problem gluing up 1” thick stock to other 1” thick stock to make 2” thick stock—as long as it’s the same species (similar expansion/contraction rates) and NOT glued cross grain.
bilyo
#7 posted 11-02-2018 05:10 PM
- Dustin
Actually, I was think more in terms of a square edge like this:
But, the one you linked is nice and does a good job of hiding the glue line.
View Tony_S's profile
Tony_S
1070 posts in 3694 days
#8 posted 11-02-2018 11:23 PM
- Aj2
I must have missed the ‘cutting corners’ part of the post…where was that?
-- “Wise men speak because they have something to say; fools because they have to say something.” – Plato
View lumbering_on's profile
lumbering_on
578 posts in 1101 days
#9 posted 11-02-2018 11:52 PM
Maybe I’m reading this wrong, but this seems like a train wreck coming. I’ve seen too many instances where family and friends ask for a ‘favour’, but then refuse to accept the fact that you aren’t just there to make them happy. If she’s just thinking she can get a superior table for half the price then there’s a good chance that one of you, likely both are going to have some hard feelings afterwards. That’s something that usually drags a whole bunch of people into the situation on both sides.
I’d make sure you really want to do this. It may be easier to ask them to get something at the nearest furniture store.
View Aj2's profile
Aj2
#10 posted 11-03-2018 12:49 AM
Keep thinking about it Tony you’ll figure it out.
-- Aj
bilyo
#11 posted 11-03-2018 03:36 AM
- cpbuck
Nobody would ever know that the interior boards were 4/4 either. Use your 8/4 pieces for edges and breadboards. Leave the interior 4/4. Saves weight, saves lumber, saves dollars, and still gives your sister the look she wants.
