Japanese saw equivalent of a western carcass saw
« back to Hand Tools forum
Forum topic by el_mustango posted 11-01-2018 05:43 AM 673 views 0 times favorited 3 replies Add to Favorites Watch
View el_mustango's profile
el_mustango
31 posts in 816 days
11-01-2018 05:43 AM
This might be an odd question, but what is the Japanese equivalent of a western carcass saw?
I’ve got two Gyokucho Ryoba saws (210mm and 270mm) which I equate to western rip and crosscut panel saws.
I’ve got a Z-Saw Dozuki saw which works superbly for cutting dovetails and tenons (so much so that I rarely touch my Disston tenon saw anymore).
I’ve got Topman(?) flush cut saw.
Just wondering if there is a Japanese saw that would take the place of a western carcass.
-- I'm a simple man. I like pretty dark-haired women and breakfast food.
3 replies so far
View Max™'s profile
Max™
121 posts in 513 days
#1 posted 11-01-2018 08:30 PM
A carcase is basically just a long dovetail saw as far as I can see, I personally like having one in crosscut to complement my smaller rip dovetail, but there’s no reason you can’t have both profiles or prefer either. Is there a 12 inch Dozuki or something, because I’d probably use one for the stuff I do with my carcase saw.
Basically if I’m not doing a cut where I need more than an inch or so cut depth but want to make sure it is exactly tucked up against a marking the full way, I grab the carcase. Many times before I set into something with my panel saw I’ll lay out the cuts with the carcase saw because it’s just a bit smaller kerf and super stiff so the panel tracks along behind it nicely.
-- One hand to hold the saw, one hand to guide it, one hand to brace the work and in the sawdust OW MY THUMB!
el_mustango
#2 posted 11-01-2018 11:37 PM
Max- that’s what I was thinking, but I wasn’t sure if I was right. Thanks!
View Max™'s profile
Max™
#3 posted 11-02-2018 05:46 PM
I mean, there may be a more seasoned expert around with better cross-knowledge, my japanese saw info is very limited as it’s basically just the american made zona ones I reversed before rehandling, but yeah, I think a carcase is used for cuts to set up drawer mounts and such, which are often going to be crossgrain and longer than 10 inches regularly enough that a little dovetail won’t cut it.
