How much danish oil
Forum topic by YouthfullMind posted 10-31-2018 03:12 PM 471 views 0 times favorited 4 replies Add to Favorites Watch
View YouthfullMind's profile
YouthfullMind
60 posts in 755 days
10-31-2018 03:12 PM
Topic tags/keywords: workbench danish oil roubo shaker
I’m almost done with my new workbench. 6’ long roubo/shaker style. I’m planning on finishing it with danish oil but I have never used it before. The general dimensions of the bench are 36” high, 72” long, 24” wide. The cabinets will be raised panel and approximately 48” long, 18” high, and 18” wide.
Will a pint be enough or will I need more?
YouthfullMind
#1 posted 10-31-2018 03:22 PM
Also, it is white oak
View JayT's profile
JayT
6356 posts in 2814 days
#2 posted 10-31-2018 03:23 PM
Pint should be enough. I only use one coat on my bench top, too many coats will make the surface overly slick. I’d probably do at least 2-3 coats on the cabinets.
-- https://www.jtplaneworks.com - In theory, there is no difference between theory and practice. In practice, there is.
View bondogaposis's profile
bondogaposis
5604 posts in 2954 days
#3 posted 10-31-2018 04:09 PM
I use 2 coats. Apply it liberally, let it set for a few minutes then wipe it tight. Wait at least 24 hours, longer if it is cold, then second coat. Don’t apply as much for the second coat. A pint will be plenty.
-- Bondo Gaposis
YouthfullMind
#4 posted 10-31-2018 04:42 PM
Thanks for the help
