Minimum overhang on sides of 5' workbench build, AKA minimum width apart of legs?
Forum topic by SMP posted 10-30-2018 08:07 PM 1612 views 0 times favorited 5 replies Add to Favorites Watch
View SMP's profile
SMP
1563 posts in 507 days
10-30-2018 08:07 PM
Hello all,
I am building a 5’ English style workbench following the English woodworker plans. In the plans, he has diagrams for the 12’ bench he builds in the videos, and for a 7’ bench. He mentions he wouldn’t suggest going smaller than 5 feet. Due to space in my garage, I am going with 5’. However, I was wondering how long of an overhang to leave on each side? On the 7’ it shows 1’ on each side. But on a 5’ bench that would make the legs 3’ apart which might look funny and not be very sturdy? Any tips here? I tried looking at some pics but hard to tell dimensions etc in most pics.
Thanks
Steve
5 replies so far
View mathguy1981's profile
mathguy1981
94 posts in 506 days
#1 posted 10-30-2018 08:11 PM
I would space them with 6-8” overhang. For the most part, you’re going to be using that for clamping right? If so, how deep are your clamps? Even my deep C clamps are only 6 inches deep.
-- Two thumbs and counting
View SMP's profile
SMP
#2 posted 10-30-2018 11:05 PM
I would space them with 6-8” overhang. For the most part, you re going to be using that for clamping right? If so, how deep are your clamps? Even my deep C clamps are only 6 inches deep.
- mathguy1981
Yeah i was thinking visually 6” makes sense and I guess for stability the wider apart the better. I just didn’t want to later realize its not enough for some vise etc. At first i will probably only have a hold fast/batten and possibly crochet. But building a face vise once i can afford the astronomically overpriced vise screw.
My clamps are probably more around 4” throat.
View YouthfullMind's profile
YouthfullMind
60 posts in 753 days
#3 posted 10-31-2018 01:20 AM
My end vise requires a 12” overhang to mount. I have a 6’ bench and went with 6” on the left end and 12” on the right. I was going to have 12” on each side, but decided to make the legs a bit wider.
mathguy1981
#4 posted 10-31-2018 04:20 PM
Why 5’ instead of 6’? Could you swing 6’ if you rotate or move a few tools around? Just thinking because 6’ would allow you to do the 12” overhang on one side for your future vise and still have 4.5’ between legs, which should give you a the same overhang as 6” around a 5-footer.
View Phil32's profile
Phil32
838 posts in 505 days
#5 posted 10-31-2018 04:28 PM
If this bench is going in a garage, will it be anchored to the studs or free standing? This could have an important bearing on the stability and the matter of overhang.
-- Phil Allin - There are mountain climbers and people who talk about climbing mountains. The climbers have "selfies" at the summit!
