Hold Down Options w/ no T-tracks
« back to CNC Woodworking forum
Forum topic by Jordan123 posted 10-30-2018 02:16 PM 1056 views 0 times favorited 8 replies Add to Favorites Watch
View Jordan123's profile
Jordan123
60 posts in 709 days
10-30-2018 02:16 PM
Hey guys,
Im trying to mill out a pocket in a serving board ive made. Because of that I cant damage the board. I also do my cnc work at a community workshop where they do not have t track in the spoilboard yet.
How would you guys recommend holding it down? My idea was some plywood blocks around it to hold it from shifting and some double sided tape to hold it down.. I am only a little worried that that up-cut bit might try to pull the piece of the spoilboard. Its a walnut piece I am trying to cut. Is this enough?
8 replies so far
View Robert's profile
Robert
3602 posts in 2087 days
#1 posted 10-30-2018 02:17 PM
Glue some sandpaper to the blocks will help.
View HokieKen's profile
HokieKen
12002 posts in 1745 days
#2 posted 10-30-2018 06:39 PM
-- Kenny, SW VA, Go Hokies!!!
View shawnn's profile
shawnn
147 posts in 1972 days
#3 posted 11-06-2018 01:27 AM
I cut these pockets using wood strips as a guide for my router, cutting with a (cheap, Yonico) guided bowl bit. Not sure if this is relevant to what you’re trying to do but I used masking tape on both the cutting board and the guide strips, then CA glue (super glue) to hold the guide strips in place. Holds the guides like a champ and when finished, the masking tape peels off cleanly.
ETA: I used to use double-sided tape but the foam carrier always allowed some movement. The masking tape doesn’t.
shawnn
#4 posted 11-06-2018 01:34 AM
Top of cutting board if anyone’s interested. Maple & Brazilian Cherry scraps, finished with a mixture of coconut oil & beeswax.
View therealSteveN's profile (online now)
therealSteveN
4642 posts in 1181 days
#5 posted 11-06-2018 03:54 AM
shawnn, I’ve been loving a Yonica flush trimmer I have been abusing. A LOT longer cut life than I ever imagined. I’ll have to look at their bowl bits. Christmas is bowl bit season, party trays are jolly gifts.
That is a nice board idea, tray to board in seconds. I wonder if with that much wood cut out, and one side flat if it will note a twist?
For the OP. If you make an oversized carrier board you can mount DeStaco clamps around the edges
Or drill access holes around the edges of an oversized carrier board and insert clamps through the hole. look for ones with a hook, and a flat foot that you can recess, crossing over to welding suppliers get a lot of different profiles.
-- Think safe, be safe
View DS's profile (online now)
DS
3360 posts in 3027 days
#6 posted 11-06-2018 01:35 PM
Double-sided speed tape along with wood blocks screwed to the spoil board at the edges of the work piece usually works for me.
View Dwain's profile
Dwain
602 posts in 4466 days
#7 posted 11-06-2018 01:53 PM
I have used carpet tape to rout the hand holds for my cutting boards and serving trays with great success. I’ve used them to hold the template on the board, and to hold the board down to the workbench.
-- When you earnestly believe you can compensate for a lack of skill by doubling your efforts, there is no end to what you CAN'T do
View oldnovice's profile
oldnovice
7517 posts in 3974 days
#8 posted 11-06-2018 08:37 PM
You may want to consider this process posted on YouTube by NY CNC, Winston Moy and others.
Using painters tape and CA glue!
At first glance it doesn’t look like it should work but in video above they are taking deep cuts in aluminum and it DOES work!
