Tensioning issues with Laguna 1412... setup question
Forum topic by hamchef1 posted 10-29-2018 01:26 PM 750 views 0 times favorited 4 replies Add to Favorites Watch
View hamchef1's profile
hamchef1
2 posts in 1932 days
10-29-2018 01:26 PM
Topic tags/keywords: bandsaw
Does anyone know if the tension blade assembly is all one piece? Part number 1412-121… mine looks like this (possibly snapped).
Long story short, I got the saw back in the spring and was then promoted at work, resulting in no shop time for the last 6 months… trying to get it setup with no luck now.
View Andybb's profile
Andybb
2342 posts in 1205 days
#1 posted 10-29-2018 08:21 PM
First of all, it’s still under warr. Just call them and send them the pic. I have a 1412 but can’t really see what you are showing. The pic is zoomed and turned.
1412 Parts diagram
-- Andy - Seattle USA
View Bill_Steele's profile
Bill_Steele
630 posts in 2333 days
#2 posted 10-31-2018 07:44 PM
I agree with Andy—you should definitely go through Laguna support. I also have a 1412.
Is the damage on your saw related to the tension quick release arm—or item #24 in the diagram Andy provided?
I can see what appears to be a broken bolt or screw in the picture you provided. I would guess that #24 has broken off of part #21. Maybe some corrosion/rust formed in there and when you went to put tension on the blade the arm could not handle the extra friction and snapped? Just a guess.
Andybb
#3 posted 10-31-2018 08:06 PM
Oh. Now I see. Looks like that eccentric should be attached to the bolt that looks sheared off. If that’s the case it would have taken a LOT of pressure on that bolt to shear it. I’d bet that even if it’s not under warr. they would replace it. They’re pretty good about standing behind their stuff.
hamchef1
#4 posted 11-10-2018 03:27 PM
Thanks for the feedback, I was able to get ahold of Laguna and sent the picture over. Great news they helping me out and my new tension arm should be here shortly.
