Advice on Hard maple dinner table project (first timer)
Forum topic by GLI posted 10-29-2018 01:23 PM 1293 views 0 times favorited 8 replies Add to Favorites Watch
View GLI's profile
GLI
1 post in 822 days
10-29-2018 01:23 PM
Topic tags/keywords: maple
Hello all, looking for some guidance. I’m working on my first ever wood project and need finishing advice. Building a large dinner table out of hard maple. I have a co worker helping me but wanting some knowledge on my side and not just going completely with how he thinks it should be finished.
My wife wants the matte natural look of the wood and not a shiny finish or darker stain, yet it still needs to be safe from being used as a dinner table. I’m also a fan of the natural matte look but would like to see more detail of the grain pop out.
With that in mind, any recommendations on what to do research on? What I’m wondering is, since we don’t plan on staining it to a dark color, does that mean only one finish material will be used? Or do you normal still apply some type of coating prior to the protective coat.
Thanks!
8 replies so far
View duc996's profile
duc996
32 posts in 2474 days
#1 posted 10-29-2018 01:58 PM
I would apply a few coats of natural danish oil to bring out the natural color of maple and let dry for a week. I would then apply at least three coats of minwax polycrylic water based poly. Of course sand in between coats. Good luck!
View Robert's profile
Robert
4338 posts in 2458 days
#2 posted 10-29-2018 04:01 PM
Yes, you may consider just going with a top coat. You’re options are basically varnishes and polyurethane.
I recently build a dining table and used EmTech 8000 conversion varnish. Very happy with it.
If you don’t have the capability to spray, I would avoid this material it really has to be sprayed.
Good to avoid stains maple is very subject to blotching.
View bilyo's profile
bilyo
1259 posts in 2080 days
#3 posted 10-29-2018 06:30 PM
As duc996 said, danish oil will pop the grain. Keep in mind that it will impart a slight amber color to the maple. If you want a lighter color, try tung oil. Apply it about the same way. Which ever one you use, make sure it is fully cured before applying a water based finish. Some might recommend applying a coat of blond shellac between the oil and the water based finish.
View FrankTuna's profile
FrankTuna
7 posts in 891 days
#4 posted 10-30-2018 05:21 PM
Yes, you may consider just going with a top coat. You re options are basically varnishes and polyurethane.
If you don t have the capability to spray, I would avoid this material it really has to be sprayed.
- rwe2156
I’ve heard good things about Target Coatings and looked at this type quickly online. Can I ask a few questions??I’m new to spraying but have a Fuji turbine system on the way.
Is this finish tricky, or doable for someone new to spraying?
It looks like its low VOC. I’ll have to spray in my basement and will wear a respirator. Are there any issues with fumes or smells that should be considered?
Thanks!!!
View Dustin's profile
Dustin
707 posts in 1717 days
#5 posted 10-30-2018 05:37 PM
- rwe2156
I ve heard good things about Target Coatings and looked at this type quickly online. Can I ask a few questions??I m new to spraying but have a Fuji turbine system on the way.
It looks like its low VOC. I ll have to spray in my basement and will wear a respirator. Are there any issues with fumes or smells that should be considered?
Thanks!!!
- FrankTuna
Frank, I did my first spray project this year using Target Coatings products (albeit, it was the EM9000 and EM6500). The odor to me was no issue: it’s hard to describe, but it wasn’t a strong chemical stench at all. As for ease of use, the 2 products I mentioned did an excellent job of self-leveling and were very forgiving-really ideal as it was my first time spraying.
If you have some scrap boards, or even just some cardboard lying around, it certainly wouldn’t hurt to practice on that. Otherwise, I didn’t find the learning curve too steep. I was using an Earlex 5500, so there was a little less configuration to fiddle with than you’ll have on your Fuji.
-- "Ladies, if your husband says he'll get to it, he'll get to it. No need to remind him about it every 6 months."
View SMP's profile
SMP
3208 posts in 883 days
#6 posted 10-30-2018 05:57 PM
Has anyone tried the Osmo Polyx oil in the Matte finish? I am curious about that one. As I have only see the satin, and it looks great and seems to protect very well.
View Bill_Steele's profile
Bill_Steele
748 posts in 2709 days
#7 posted 10-30-2018 06:23 PM
If you want to add color you can use a stain or a dye OR you can add the stain or dye to the urethane. I would suggest researching the use of water versus oil based finishes. I would suggest using a wipe-on finish. Research how to sand and what type of abrasive to use between coats to achieve a smooth finish.
I suggest General Finishes Oil and Urethane – Satin. This is a simple to apply finish that will provide protection but not appear as a film on the wood. The oil will help bring out the figure and the urethane will provide protection. I just wipe it on out of the can. Sand lightly with a medium to fine synthetic abrasive pad between coats. Four coats should do the trick.
View OSU55's profile
OSU55
2718 posts in 2966 days
#8 posted 10-30-2018 10:18 PM
I add some color to most projects, sometimes a little sometimes a lot. Helps bring out the grain. Maple blotches, and needs to be conditioned and you can read about blotch control here. Rest of my comments are based on your very limited experience – there are other finishes and methods but kiss. Also read the blog about oils vs poly. Being a dining table it should be finished with poly, oil based unless you can spray (let me know different instructions). I use plain old minwax poly, satin in this case for a matte finish. It will be thinned 1:1 with mineral spirites. Research wd lockwood oil based dye. Dissolve the dye with naptha.
Have test boards. Use them to test the finish schedule or steps. Completely finish a test board before touching your project. The dye will be mixed into the thinned poly. Test until you get the desired color and intensity. Apply conditioner as described. Apply poly like danish oil.Flood the surface with the poly and dye, keep wet for 10 min, wipe off, let dry a few hrs, repeat. Now apply the poly as a wiping varnish – plenty of info out there – with or without dye, depends on color and intensity you want. That should keep you researching for a while.
