Problem with dovetail jig
« back to Joinery forum
Forum topic by rut posted 10-29-2018 01:09 AM 944 views 0 times favorited 17 replies Add to Favorites Watch
View rut's profile
rut
73 posts in 2994 days
10-29-2018 01:09 AM
I’m using the porta cable dovetail jig and for some reason the width of the cuts are not correct. I’ve attached a pic. I’m wondering if the router template bearing is not the correct one. Does anyone know what the part number is for that jig? Is it suppose to fit tightly within the jig? Would appreciate any help.
Thanks
Rut
17 replies so far
View johnstoneb's profile
johnstoneb
3131 posts in 2785 days
#1 posted 10-29-2018 02:23 AM
I think you’re to shallow on the vertical piece. The tails. I always cut some on a scrap piece the same shickness until I get it right.
-- Bruce, Boise, ID
View Redoak49's profile
Redoak49
4360 posts in 2601 days
#2 posted 10-29-2018 11:01 AM
Generally, how loose or tight the dovetails fit is controlled by the depth of cut…ie the height of the router bit.
View Markmh1's profile
Markmh1
114 posts in 1056 days
#3 posted 10-29-2018 01:10 PM
I believe you have something out of adjustment.
I would check how far the cutter is moving in on the horizontal plane first. It also looks like the depth is incorrect, perhaps too shallow. In any event, it does look like a compound problem. Two things out of whack.
Cutting 1/2 blind dovetails on this fixture was difficult for me, it didn’t happen right away. Start over, take a deep breath, and recheck EVERYTHING. IMO, the directions suck, but it looks like you’re very close.
Mark
Redoak49
#4 posted 10-29-2018 01:20 PM
The manual is very clear. This is the same with almost all dovetail jigs.
If the joint is too loose you need to take a deeper cut.
If it is too tight, take a more shallow cut.
Try a deeper cut and see what happens. You may need to make several trials to get it right. Keep track of your changes and the results.
View HokieKen's profile (online now)
HokieKen
12045 posts in 1751 days
#5 posted 10-29-2018 01:24 PM
As stated, tweak your cut depth on some scrap before you work on your project pieces.
-- Kenny, SW VA, Go Hokies!!!
View bilyo's profile
bilyo
966 posts in 1715 days
#6 posted 10-29-2018 02:54 PM
You asked about the size of the guide bearing. In addition to the comments above, it is important that the correct guide bearing be used to match the finger template being used. The Porter Cable jig came with several sized bearings. Use the one that fits between the template fingers with minimum side play. If that bearing is missing from the set, you will need to get a replacement. You will not get good fitting DTs without it. I’m going from memory, but I think that bearing guide you need is 1/2”. I don’t know if you can buy them individually or not, but it is a standard size and will be included in any set you buy.
Otherwise, it looks like you are close with your settings. Once you get the correct bearing, make some test cuts and make some fine adjustments in cutting depth.
View rut's profile
rut
#7 posted 10-29-2018 09:28 PM
I guess I wasn’t thinking it was a depth issue. The depth appears really close to me. But the side to side space doesn’t look like it would be fixed by changing the depth. I’ll play around with it though.
Thanks
johnstoneb
#8 posted 10-29-2018 09:39 PM
Too loose and too tight is always a depth issue.
-- Bruce, Boise, ID
View Ocelot's profile
Ocelot
2383 posts in 3250 days
#9 posted 10-29-2018 09:42 PM
I have the omnijig 24 and tried for a few days to make one good joint and put it aside a few years ago. When you figure it out, write about it.
In my case, I had trouble with the boards slipping in the clamps.
-Paul
Redoak49
#10 posted 10-29-2018 09:58 PM
I have a Leigh jig and have had problems with slippage also. I glued some sand paper back to back and put it between the wood and clamp. This prevented slippage.
View Kazooman's profile
Kazooman
1413 posts in 2565 days
#11 posted 10-29-2018 10:03 PM
I have a Leigh dovetail jig and can concur that your problem looks to be related to the depth setting. If this was a guide bushing problem I would expect to see more of a variation in the side to side fit of the joints. Some might be OK while others are too wide depending on how you held the bushing against the sides of the template when making the cut. They seem to be uniform suggesting that there was little or no play in the fit.
As others have suggested, you need to do trial runs on “scrap” to dial in the proper settings. I put “scrap” in parentheses, because the pieces you use for this are critical to the eventual outcome. Use test pieces that are exactly the same thickness as your good workpieces. That takes a lot of potential concerns out of the equation. Once you have the settings adjusted to give a well fitting joint keep the last set of test pieces and label them (thickness, specific cutter used, etc.). You can use them to get you very close the next time you need to set up the jig and router for the same joint.
bilyo
#12 posted 10-29-2018 10:42 PM
I guess I wasn t thinking it was a depth issue. The depth appears really close to me. But the side to side space doesn t look like it would be fixed by changing the depth. I ll play around with it though.
Thanks
- rut
Assuming your guide bearing is correct, I agree that depth is probably the culprit. Because you are cutting both pins and tails simultaneously, the depth will always appear to be close if not right on. However, because the sides are tapered, you will find as you make adjustments the sides will come closer together if your adjustments are in the correct direction. Read your instructions carefully.
View rut's profile
rut
#13 posted 10-30-2018 01:25 AM
I do want to clarify that when the router (and bushing) was inbetween the fingers of the template that there was movement from one finger edge to the opposite. The bushing width did not match the width between the fingers. Does that seem normal or should it be the same width?
Redoak49
#14 posted 10-30-2018 11:14 AM
Please look in the manual to find out the correct bushing size. I just looked at the manual and it clearly states which bushing and router bit are used for each type of joint.
I have a little play between the fingers and bushing on my Leigh jig.
Have you tried changing the height of the router bit to see if that helps?
View Jeff's profile
Jeff
516 posts in 3807 days
#15 posted 10-30-2018 12:30 PM
Porter Cable also uses their own router bits. Make sure you use the ones that came with or are specified in the manual. Not all dovetail bits work, as I’ve experienced.
