epoxy opps
Forum topic by dwicked posted 10-28-2018 05:39 PM 610 views 0 times favorited 8 replies Add to Favorites Watch
View dwicked's profile
dwicked
7 posts in 451 days
10-28-2018 05:39 PM
okay have another question I was using some epoxy to fill some cracks on some Sawmill cutoffs turning them into charcuterie boards and the latest round of epoxy didn’t come with metering pumps so while I balling I must have been a little light on resin because it’s not setting up the first poor setup fine second for seems to be light on resin it’s been 48 hours and still really gooey is there a way to get this set or does it need to be start it over
8 replies so far
View lumbering_on's profile
lumbering_on
578 posts in 1092 days
#1 posted 10-28-2018 05:59 PM
At this point, I’d call a mulligan and remove the epoxy. You can see a good way to do it from West System.
https://www.westsystem.com/instruction-2/epoxy-basics/clean-up-removing/
View MrUnix's profile
MrUnix
7579 posts in 2801 days
#2 posted 10-28-2018 06:32 PM
Try heating it up… either with something like a hair dryer, or if it’s small enough, in the oven for a while.
View Clarkswoodworking's profile
Clarkswoodworking
289 posts in 735 days
#3 posted 10-28-2018 06:56 PM
I don’t see a way to ad hardener now ?
View shipwright's profile
shipwright
8452 posts in 3400 days
#4 posted 10-29-2018 12:02 AM
With epoxy ratio is important. It is not a catalyst reaction. Both parts are consumed at a specific ratio. If there is too much of either there will be ions of that component left in the material after all the available crosslinking has been done. These free ions will adversely effect the properties of the compound.
Yes, it’s too late. Remove the muck and measure more carefully.
Also be aware that when the material is cold and there are viscosity differences between the components pumps can be less that accurate.
View Redoak49's profile (online now)
Redoak49
4343 posts in 2590 days
#5 posted 10-29-2018 01:54 AM
I mix my epoxy by weight. With T88, it is a ratio of 100 resin to 83 hardener. I just never trusted the pump things.
View Dustin's profile
Dustin
705 posts in 1342 days
#6 posted 10-29-2018 12:39 PM
- Redoak49
This is a great suggestion. I don’t ever do it, which is probably why my epoxy mixes and baked goods equally turn out poorly :p
-- "Ladies, if your husband says he'll get to it, he'll get to it. No need to remind him about it every 6 months."
dwicked
7 posts in 451 days
#7 posted 10-29-2018 05:33 PM
Thank you all. It also looks like the sent me the wrong mixing ratios I found out when I contacted the supplier about where my pumps where at ( I know close at best) think I’m going to hit harbor freight today for a scale
Redoak49
#8 posted 10-29-2018 10:17 PM
If you are mixing by weight, make certain you know the weight ratio which can be different than a volume ratio.
