Determining mortise depth
Forum topic by groland posted 10-28-2018 02:52 AM 470 views 0 times favorited 6 replies Add to Favorites Watch
View groland's profile
groland
221 posts in 4023 days
10-28-2018 02:52 AM
Topic tags/keywords: determining mortise depth
If I am making two mortises in a table leg for the table’s side rails, is it better to make the mortises intersect or stop short of intersecting? If I do the former, I will have more glue surface on the tenon, but the joint might be weaker. If the mortises do not intersect, the leg might be stronger, but there will be less glue surface on the tenon.
Is one method better than the other?
View lumbering_on's profile
lumbering_on
578 posts in 1101 days
#1 posted 10-28-2018 03:12 AM
Yes?
I usually use a haunched m&t as it gives better gluing surface, and provides excellent support. However, I’ve never had them meet.
View TheFridge's profile
TheFridge
10859 posts in 2097 days
#2 posted 10-28-2018 03:23 AM
I don’t let them meet but I alway make them as long as possible.
View Rich's profile
Rich
5157 posts in 1201 days
#3 posted 10-28-2018 03:37 AM
You can always miter the ends of the tenons to get maximum length. However, unless your legs are very thin, I wouldn’t worry about it.
View MrRon's profile
MrRon
5813 posts in 3855 days
#4 posted 10-28-2018 03:59 PM
Here are 3 possible M&T joints that can be made. In these examples, the legs are 2”x2” and the tenoned pieces are 3/4” stock. The tenons are the normal relationship of a 3/8” tenon on 3/4” stock.
The left hand sketch is where the mortises intersect.
The middle sketch shows where the tenons are mitered.
The right hand sketch shows where the tenons have been shifted to the far face of the wood. This allows for more “meat” in the leg. Naturally, if design permits, the pieces can be offset giving more strength to the joint.
View ocean's profile
ocean
196 posts in 1445 days
#5 posted 10-28-2018 05:33 PM
I’ve always made my mortises in a leg met. I also have almost always had small legs, so I was trying to get max glue surface. As Ron shows in drawing #2. So far never had any problem with joint failure.
-- Bob, FL Keys
View John_'s profile
John_
225 posts in 2317 days
#6 posted 10-29-2018 05:06 AM
I recently found myself in a similar situation and ended up using an ‘interlocking tenon’. Here is a pic of some scrap pieces I used for practice
