need bowl gouge comparison
« back to Woodturning forum
Forum topic by Karda posted 10-28-2018 01:00 AM 2041 views 0 times favorited 20 replies Add to Favorites Watch
View Karda's profile
Karda
3042 posts in 1607 days
10-28-2018 01:00 AM
I am going to need to replace my .5 inch bowl gouge soon probably next year, But what is good. I am using Benjamin Best and they work fine and I have no problem staying with them. I would like to upgrade and was wondering what is the difference between the different brands. I am a hobby turner and resharpening a few extra times won’t hurt my production rate. How are hurricane tools thanks Mike
20 replies so far
View lew's profile
lew
13332 posts in 4808 days
#1 posted 10-28-2018 02:47 PM
I like carbide tipped tools but started with Pinnacle tools from Woodcraft and they did a fine job. I also read good things about Crown tools although I haven’t tried them. Neither brand is quite as inexpensive as Benjamin’s.
View bigJohninvegas's profile
bigJohninvegas
978 posts in 2515 days
#2 posted 10-28-2018 05:15 PM
Hi Karda, I was given a set of Hurricane tools, and was not impressed. I do have a couple of ben best spindle gouges that I bought to make beading tools out of. But never used it as a spindle gouge. When I was gifted the set of Hurricane tools I had already been using Sorby and Thompson tools. Huge difference in how long the tools stay sharp.
I started out with a set of Sorby tools about 5 years ago. And I still use all of them except the bowl gouge.
You were smart to start with that cheap ben best bowl gouge. I ruined that Sorby gouge pretty quick learning to sharpen it. I met Jimmy Clewes almost as soon as I started turning. (Lucky me we live in the same city), and he introduced me to Thompson tools. Night and day difference in quality.
Most of my Thompson tools are the Jimmy Clewes signature line, and I bought all of them From Jimmy here in town. http://jimmyclewes.com/ That is just convenient for me since I can just go pick them up with no mail order to deal with.
But you can order from Doug thompsons site as well. http://thompsonlathetools.com/ Ask questions about the different signature lines. There are different shapes to the flute. U or V shape and depth. I only used what Jimmy sells.
I bought that first 1/2” bowl gouge back in 2015, and it has a little life left in it, but I did just pick up another last spring. I also use both 3/8” bowl and spindle gouge, a parting tool, and the box scraper. All of which are orignals that I bought several years back now. I will most likely wear out another 1/2” bowl gouge before any of the others. It is a go to gouge for me.
Lately I have been spending all most of my time trying to do hollow forms. Failing at it I should say, And am experimenting with carbide. I do prefer to do all I can with HSS gouges. What I learned 1st.
But I purchased a Mike Jackofsky hollow pro tool back in 2015. And have since picked up the Mate tool that Jimmy sells.
This has my gouges lasting longer too, as I spend a fair amount of time fiddling around with carbide.
One last bit, While I like Thompson tools, I was told early on by several that any of the HSS Sheffield steel tools were good quality, and that they all come from the same steel plant in England. Sorby, Crown, Henry Taylor, etc.
Since that was pointed out to me, Crown for example has released a Powdered metal line like what Doug Thompson tools are made of. No idea where Crown sources that from.
good luck
-- John
View waho6o9's profile
waho6o9
9016 posts in 3630 days
#3 posted 10-28-2018 05:30 PM
Thompson uses better metal and the results are worth the cost.
View TheDane's profile
TheDane
5952 posts in 4716 days
#4 posted 10-28-2018 06:33 PM
- waho6o9
A lot of people say Doug’s tools are expensive … nobody says they aren’t worth it.
Karda
#5 posted 10-29-2018 04:20 AM
ok thanks
View Wildwood's profile
Wildwood
2954 posts in 3188 days
#6 posted 10-29-2018 10:41 AM
View Sawdust2012's profile
Sawdust2012
259 posts in 2766 days
#7 posted 10-29-2018 10:47 AM
https://huntertoolsystems.com/
I have been really impressed with these carbide tools. Unlike my experience with EWT, I get almost no tear out. The cutters come razor sharp and stay sharp for a long time.
View OSU55's profile
OSU55
2774 posts in 3043 days
#8 posted 10-29-2018 11:56 AM
I have both bens best and hurricane gouges, rate them about the same. I will be replacing my most used bowl gouge, 5/8” OD, with a Thompson when the time comes. As well as the bb and hurricane tools perform I have no reason to replace the less used tools, only those that I use up the quickest. I dont do a lot of spindle turning, more bowls and platters, hence bowl gouge replacement. I use the 5/8” much more then 1/2”. I use the largest tool I can for each project.
Carbide – for spindle and bowl turning I much prefer hss gouges, even for roughing, they work faster, cutting vs scrapind. I do use carbide some for hollowing which is a scraping cut anyway and surface finish not as important.
TheDane
#9 posted 10-29-2018 02:29 PM
- Sawdust2012
That’s because Mike Hunter uses carbide cutters that are dished (not flat) so they slice the fibers. Hunter tools are excellent for hollowing. They can, however, be very aggressive if not properly used.
View Hockey's profile
Hockey
182 posts in 1465 days
#10 posted 10-29-2018 03:17 PM
Sorry I have no basis upon which to make a comparison; but, I am very pleased with my 1/2” Sorby fingernail bowl gouge.
Karda
#11 posted 10-29-2018 04:08 PM
decisions decisions thanks that gives me a lot to think about thanks Mike
View Jim Jakosh's profile
Jim Jakosh
26060 posts in 4159 days
#12 posted 12-13-2019 10:36 PM
I was at the point of ordering a new set of bowl gouges and have looked at Hurricane M42 cryo PM m42 gouges, Crown m42 and Cryo pm M42 razor gouges and was looking for a site that reviews all of them and did not find a full answer. On the AAW site, a lot of people prefer Thompson tools so I called Doug Thompson and had a good conversation on what the difference is. His tool s are made of a tool steel that is a notch above M42 and have 10% vanadium in them for wear resistance. They are priced lower than Sorby, Crown,Carter or Hurricane. After takling to Doug, I ordered a set of his tools. I had been using Benjamin’s Best from Penn State for years and lately the 5/8 gouge will not stay sharp for very long at all on mesquite or pistachio wood. I’ll put out a review of them after I give them a workout on some dry mesquite.
Cheers, Jim
Karda
#13 posted 12-13-2019 10:41 PM
ok thats good to know
View AndyJ1s's profile
AndyJ1s
485 posts in 808 days
#14 posted 12-16-2019 02:33 AM
Mike Hunter’s Osprey and Hercules series tools present the dished cutter at a 45 degree downward angle, so they mimic a similarly sized gouge in use, including the ability to “ride the bevel”. Except you just rotate the cutter when it gets dull, and eventually replace it. Being carbide, that will take a while…
Andy
-- Andy - Arlington TX
View Lazyman's profile
Lazyman
6930 posts in 2440 days
#15 posted 12-16-2019 03:40 AM
I have both Hurricane and BB bowl gouges. They look and perform so similar to each other, I would not be surprised if they are the same tool with different brands burned into the handles. Even if they are not the same maker behind the different brands as I suspect, there is no reason to switch from one to the other.
