Help finding a part for my old Milwaukee/Delta 14" bandsaw
Forum topic by Clarkie posted 10-27-2018 10:57 PM 1269 views 0 times favorited 7 replies Add to Favorites Watch
View Clarkie's profile
Clarkie
489 posts in 2453 days
10-27-2018 10:57 PM
Hello, I need a part for my 1938-40’s Milwaukee/Delta 14” bandsaw. It is the bar that holds the upper blade guide blocks. I appreciate any help you can offer, thanks, Clarkie.
7 replies so far
View MrUnix's profile
MrUnix
7602 posts in 2810 days
#1 posted 10-27-2018 11:29 PM
Are you talking about the large hex guide rod? It’s a pretty plain 7/8” hex rod that can be found at just about any place that sells metal rod (like a welders supply house). Otherwise, flea-bay is probably your best bet. I believe the newer round ones will work as well, but I have no first hand experience to verify that claim with.
Clarkie
#2 posted 10-28-2018 12:48 AM
Hello Brad, thanks for responding. No, it’s not the rod, it’s the piece that holds the guide blocks. I have the whole mechanism, but am in need of the part that holds the cool blocks to guide the blade.
Clarkie
#3 posted 10-28-2018 12:56 AM
MrUnix
#4 posted 10-28-2018 02:08 AM
You mean this one?
Those are available all over the place from the usual aftermarket suppliers, like ToolPartsDirect, Mikes Tools, Amazon, Renovo Parts, flea-bay, etc..
Clarkie
#5 posted 10-28-2018 02:23 AM
Hello Brad, yes that’s the part, but it’s been said the new re-pros won’t fit a Milwaukee/Delta. Maybe it’s worth trying, and do a little adjusting perhaps. Thanks Brad, I’ll let you know if I do.
MrUnix
#6 posted 10-28-2018 03:45 AM
Hello Brad, yes that s the part, but it s been said the new re-pros won t fit a Milwaukee/Delta. Maybe it s worth trying, and do a little adjusting perhaps. Thanks Brad, I ll let you know if I do.
- Clarkie
Not sure where you heard that, but those brackets have remained the same since those saws were first introduced decades ago. As long as it claims to be a replacement for Delta part #LBS-131 or it’s newer #426-02-014-0004, it should work just fine.
I did have to replace one on my 1950 Delta about a year ago… it developed a crack near the set screw that prevented it from tightening enough to keep the guide block positioned. I picked up a new one from ereplacementparts – which fit perfect and looked identical to the one that was originally on the machine.
Clarkie
#7 posted 10-28-2018 04:05 PM
Hello Brad, thanks for the help. I just got through ordering the part from the site you sent. Now the restore continues. God bless, Clarkie.
