Looking for low cost black hinges for a vanity
Forum topic by a1Jim posted 10-25-2018 10:58 PM 895 views 0 times favorited 17 replies Add to Favorites Watch
117909 posts in 4186 days
10-25-2018 10:58 PM
Topic tags/keywords: question
Hi Friends
I’ve been looking all over the net to find some black hinges in the 2 1/2”-3” range by 5/8 or an inch.
I’m making a vanity in roughly an Arts n crafts style and have pulls I bought from someone on LJs a number of years ago but did not get any hinges the only ones I’ve seen are in the $15-$29 each range which might make sense if I built this to be an authentic A&C project but It’s just going to have that flavor, not a high-end piece.
The other hardware I have is black has anyone had success painting hinges and having the paint hold up?
I’d appreciate any help you can give thanks Jim
17 replies so far
View 000's profile
000
2859 posts in 1508 days
#1 posted 10-25-2018 11:09 PM
Van Dykes Hardware is the only place I can think of off hand to try.
View ralbuck's profile
ralbuck
6316 posts in 2876 days
#2 posted 10-25-2018 11:12 PM
There are chemicals that will blacken the plain metal (silver-colored) ones. I think a U-Tube search on blackening metal may answer your question.
I have been in sticker shock too when pricing any vintage appearing hardware.
-- Wood rescue is good for the environment and me! just rjR
#3 posted 10-25-2018 11:32 PM
Thanks for your help ralbuck I’ll see if I can find that youtube.
View KYtoolsmith's profile
KYtoolsmith
113 posts in 469 days
#4 posted 10-25-2018 11:36 PM
Yes, six or so years ago when I built my garage cabinets, I used inexpensive T hinges that I modified with file and hacksaw to disguise them and then wire wheeled the factory finish off. Painted with rattle can black semi-gloss… Still good today.
Regards from Kentucky!
-- "Good enough" is just another way of saying "it could be better"...
View GR8HUNTER's profile
GR8HUNTER
6828 posts in 1322 days
#5 posted 10-25-2018 11:37 PM
I think I might have the old style ones…. how many sets do you need ? I will get a picture or 2 :<))
View Jerry's profile
Jerry
3313 posts in 2257 days
#6 posted 10-25-2018 11:38 PM
Surprisingly Home Depot has got some really nice looking A&C style hinges for not very much money.
-- There are good ships and there are wood ships, the ships that sail the sea, but the best ships are friendships and may they always be. http://www.geraldlhunsucker.com/
#7 posted 10-25-2018 11:43 PM
Thanks “J” I didn’t see the size I wanted and they are another place that wants $15 a hinge for what they do have.
#8 posted 10-25-2018 11:50 PM
Thanks Ky that’s encouraging.
Thanks ,I only need two sets Tony.
Thanks Jerry but all I see at HD are people door hinges and surface mounter cabinet hinges that are black these are butt hinges mortised in the door and face face frame.
#9 posted 10-26-2018 12:52 AM
If I can’t find a factory finish I may try this and see how it holds up.
https://www.youtube.com/watch?v=bvS1Xpgs8CU
35211 posts in 5010 days
#10 posted 10-26-2018 01:15 AM
Jim maybe something like this on ebay
https://www.ebay.com/itm/6106-Black-Butt-Hinge-10-pcs-FREE-SHIPPING/352478063066?epid=1131443648&hash=item52115469da:g:F-0AAOSwOgRbj~Ve:rk:78:pf:0
They also have piano hinges in black you could cut to length.
View doubleDD's profile
doubleDD
8977 posts in 2652 days
#11 posted 10-26-2018 02:20 AM
Hi Jim. I made new tops for our end tables 4 years ago. Wanting the same hinges but not having luck finding what I needed, I went with painting the old. I just cleaned the old ones with lacquer, sprayed on a primer, sprayed with black lacquer, then a coat of clear satin lacquer. They still look fine today. This top of this table gets cleaned a lot since I’m always making a mess on it. Worth doing. Good luck.
View Richard's profile
Richard
11309 posts in 3642 days
#12 posted 10-26-2018 02:28 AM
If I can t find a factory finish I may try this and see how it holds up.
- a1Jim
Good choice Jim!
-- Richard (Ontario, CANADA)
View Rayne's profile
Rayne
1298 posts in 2149 days
#13 posted 10-26-2018 02:36 AM
View Andybb's profile
Andybb
2392 posts in 1213 days
#14 posted 10-26-2018 03:04 AM
- ralbuck
If there is no rubber or plastic heat them with a torch then dip them in used motor oil.
-- Andy - Seattle USA
#15 posted 10-26-2018 04:16 AM
Thanks everyone, looks possible that one of these will work I’ll double check with the customer(my wife)
