How to find a project
« back to LumberJocks.com Site Feedback forum
Forum topic by Farrout posted 10-24-2018 12:03 PM 948 views 0 times favorited 13 replies Add to Favorites Watch
View Farrout's profile
Farrout
188 posts in 3763 days
10-24-2018 12:03 PM
Is there a way to search projects?
For example, I want to search for corner tables.
The search block searches all of the site.
Thanks
Dennis
-- If we learn from our mistakes, I should be a genius!
13 replies so far
View Redoak49's profile
Redoak49
4356 posts in 2598 days
#1 posted 10-24-2018 01:09 PM
Simple….try adding projects to your search terms
View mahdee's profile
mahdee
4291 posts in 2377 days
#2 posted 10-24-2018 01:28 PM
I am not sure if I understand you correctly. I typed corner table in search and as usual, the first 4-5 are off the site advertisements but the rest show lumber jock’s projects.
-- earthartandfoods.com
View GR8HUNTER's profile (online now)
GR8HUNTER
6828 posts in 1322 days
#3 posted 10-24-2018 01:34 PM
try it through tags :<))
View tyvekboy's profile
tyvekboy
1961 posts in 3622 days
#4 posted 10-24-2018 02:06 PM
This is how you search using the TAG option. What’s cool about this method is that you will get all the THUMBNAIL pictures of the projects in the search results.
On your browser window where you typed in LUMBERJOCKS.COM to get to the site (also know as the ADDRESS BAR) you would type the following to search for projects that have the tag TABLE .
http://lumberjocks.com/projects/tag/table
If you want to seach for other TAGS just replace the word TABLE with what you’re looking for.
Searching for more than ONE word tags is a little different. For example if you wanted to search for SIDE TABLE you would have to type in SIDE+TABLE (not necessarily in all caps).
For those posting projects, this is one reason to add TAGS to your project postings. It makes it easier for people to search through the 143,000 plus projects here on LJ. Also, when you add tags, think about the terms people would search for your projects.
This is the TAGS that someone used with their project as an example:
Here is another example of tags used with a project posting:
If you’ve posted projects but didn’t add TAGS, you can always go back to those projects and EDIT the posting and add tags to it.
Hope this helps.
-- Tyvekboy -- Marietta, GA ………….. one can never be too organized
View Rich's profile
Rich
5152 posts in 1198 days
#5 posted 10-24-2018 03:18 PM
To pin your search to only pages in the project area, use this:
corner table and inurl:projects
You’ll notice that projects have “projects” in the URL. Adding “and inurl:projects” narrows down the search to that.
View MikeDilday's profile
MikeDilday
284 posts in 1068 days
#6 posted 11-30-2018 02:12 AM
I cannot start a new topic because it says “You cannot post a new topic until your first post has been reviewed and approved.” I used the contact us form several times but no answer. Hopefully someone will see this and either fix it or tell me to get lost so I don’t worry about it any more.
-- Michael Dilday, Suffolk, Va.
View WoodenDreams's profile
WoodenDreams
887 posts in 520 days
#7 posted 11-30-2018 10:28 AM
One of the ways I’ve got ideas for projects searches was to go to www.bing.com/images then type in “corner tables” or what other images you’d like to see, in the bing image search. you will also have tabs on the image pages with similar suggested searches.
View Rich's profile
Rich
#8 posted 11-30-2018 03:19 PM
One of the ways I ve got ideas for projects searches was to go to www.bing.com/images then type in “corner tables” or what other images you d like to see, in the bing image search. you will also have tabs on the image pages with similar suggested searches.
- WoodenDreams
That’s exactly what I tell potential clients to do, and what I do for ideas on new projects. I think the thread was originally about searching projects on LJ, and the “and inurl:projects” I posted about above will do that.
WoodenDreams
#9 posted 12-01-2018 06:59 AM
In the search engine enter your topic and click. The first 4 or 5 results are normally ads, just like a google search, scroll down and you’ll see the results your looking for, or change the name of the search, corner table, next try end table, entry table, or hall table. Once you see a project pic you like, go to that LJ’s home page to check out his other projects.
View DannyW's profile
DannyW
255 posts in 406 days
#10 posted 12-18-2018 05:01 PM
This may be a dumb question but I have tried searching using both Safari and Chrome (MacOS) and cannot see a way to get to the next page of search results. The title at the top of the searches indicates 709 search results but when I scroll down to the bottom of the page there is no next button, only a Google ad; is this covering the button? I am new to the site and see that there are a great many helpful and knowledgable people here but so far the website itself (forum software) has been frustrating to use.
-- DannyW
View Underdog's profile
Underdog
1438 posts in 2645 days
#11 posted 12-18-2018 05:05 PM
- DannyW
I’m having that same problem today. Used to I could see where to click to find the next page of results. Now it’s… missing.
-- Jim, Georgia, USA
DannyW
#12 posted 12-18-2018 05:30 PM
I m having that same problem today. Used to I could see where to click to find the next page of results. Now it s… missing.
- Underdog
At least I am not the only one that is having problems. For a little bit there I thought I was just being blind.
-- DannyW
View Jack Lewis's profile
Jack Lewis
576 posts in 1687 days
#13 posted 12-18-2018 08:54 PM
- WoodenDreams
Pinterest is also a good place to look.
-- "PLUMBER'S BUTT! Get over it, everybody has one"
