Tabletop thickness for 12’ Shaker dining table
Forum topic by Mark posted 10-17-2018 08:48 PM 862 views 0 times favorited 7 replies Add to Favorites Watch
View Mark's profile
Mark
58 posts in 878 days
10-17-2018 08:48 PM
Ive been commissioned to build 4 12’ tables for a client who is restoring an old school building for use as an events venue.
They’re pretty direct about what they want: Poplar, aged, tapered legs as skinny as possible, tabletop as thin as possible. Easily stored.
Well, I’ve come up with a design I like that’s collapsible, but I’m unsure about the top. I provided two quotes – one based off 4/4 and one off 5/4. I’m worried that starting off with 4/4 rough sawn could leave me with as little as 3/4-13/16s, which in my opinion a) might look cheap, b) might look disproportionate, c) weaker tabletop.
I’ve suggested that we can get the 5/4, go to 1”, and I can bevel the underside if she wants a skinnier appearance.
Am I right to push for this? Assume that the base is good and beefy, do I need to worry about structural integrity as far as the tabletop itself goes? I’ve build 12’ tables before, but it was from 8/4 Alder.
7 replies so far
View PPK's profile
PPK
1630 posts in 1411 days
#1 posted 10-17-2018 09:44 PM
Oh man, yeah, 4/4 would certainly be too thin. 5/4 would be better. I guess part of it really depends on your design too. A skirt can help with stability, as well as if you’ve got some nice strong support under that 12’ span…
-- Pete
View Jared_S's profile
Jared_S
273 posts in 561 days
#2 posted 10-17-2018 10:00 PM
This is 10’ and 1.375” finished thickness with 4” aprons. It’s as thin as I would go.
View Mark's profile
Mark
#3 posted 10-17-2018 10:10 PM
Still working on the precise design details. The client does want the table to appear fairly primitive (not rustic), somewhat puritan-era. A lot of those tables were very thin, with long expanses away from the feet at each end.
Other than thick aprons and a stretcher, what else could I do? Client likes this style, though yes.. note the sag. Facepalm.
View Lazyman's profile
Lazyman
4474 posts in 1989 days
#4 posted 10-18-2018 12:31 PM
I’ve got a dining room table that expands to 10’ that doesn’t have huge aprons (no sag) but the mechanism that makes it expand for the leaves is metal. Perhaps you could shore up or stiffen the aprons and top with some 1” angle iron? If you put it right up against the apron and color it to blend in with a finish on the bottom, it would be almost unnoticeable.
View PPK's profile
PPK
#5 posted 10-18-2018 01:11 PM
Ha! I meant Apron, not skirt. Der da der.
-- Pete
View bondogaposis's profile
bondogaposis
5604 posts in 2953 days
#6 posted 10-18-2018 02:09 PM
I wouldn’t go thinner than 5/4, 6/4 would be better. Bevel the underside and they won’t know the difference anyway.
-- Bondo Gaposis
Lazyman
#7 posted 10-18-2018 02:56 PM
I ve got a dining room table that expands to 10 that doesn t have huge aprons (no sag) but the mechanism that makes it expand for the leaves is metal. Perhaps you could shore up or stiffen the aprons and top with some 1” angle iron? If you put it right up against the apron and color it to blend in with a finish on the bottom, it would be almost unnoticeable.
- Lazyman
I forgot to mention that the top is only 3/4” thick including veneer. I have never checked to see if the core is particle board or real wood, but even without aprons that go the entire length (because of the leaves), it seems to be plenty strong.
