lathe dust hood
« back to Woodturning forum
Forum topic by Karda posted 10-13-2018 11:19 PM 617 views 0 times favorited 4 replies Add to Favorites Watch
View Karda's profile
Karda
1956 posts in 1157 days
10-13-2018 11:19 PM
I have a small lathe from HF. I want to make a dust hood but because its small I can’t mount it to centers. any ideas how I can mount it to the bench or to the out side of the lathe, I will use plywood to makemit bt am open to suggestions. I am useing my craftsman shop vac, hose end is 1.25”
View Lazyman's profile
Lazyman
4485 posts in 1990 days
#1 posted 10-14-2018 01:30 AM
Find a gooseneck or architect’s desk lamp at a garage sale that is designed to clampto a desk and replace the lamp with your hood. You could just make a clamp with some plywood and a bolt too. Rockler makes a dust hood designed to attach to the ways of the lathe that might give you some ideas. There are some pictures of it mounted on mini lathes similar to the HF one.
Karda
#2 posted 10-14-2018 02:23 AM
ok thanks that helps
View mel52's profile
mel52
1181 posts in 868 days
#3 posted 10-14-2018 03:32 AM
I use the clear dust hood from Woodcraft, and it’s on sale now for $24.95. I made a bracket that clamps to my lathe, and got a reducer to hook up to a 2 1/2 hose. Works excellent on dust and just fair on chips. Mike
-- MEL, Kansas
View Kelly's profile
Kelly
2626 posts in 3547 days
#4 posted 10-16-2018 03:04 PM
The one I use for my little lathe wanders around the back side of my lathe [and makes a HUGE difference]. The new version will sit on the floor, so it can be used on the little or the big lathe. It will be adjustable in height, and will be able to move forward and back on the floor.
It’s just pipe with ends installed. The stand is slotted plywood. Of course, the locking knobs are just T-nuts and ply.
