blades too short?
« back to Scrollsawing forum
Forum topic by woodsmithshop posted 10-13-2018 05:10 PM 735 views 0 times favorited 7 replies Add to Favorites Watch
View woodsmithshop's profile
woodsmithshop
1401 posts in 4154 days
10-13-2018 05:10 PM
Anyone have trouble with putting blades in an Excalibur scroll saw? the last time I used my saw it worked fine, ( 5 or 6 months ago) blades went in with no problem, now it looks as if the blades are about 1/2” short can’t get both ends to lock down in place. is there an adjustment for this? Anyone have a similar problem.
Any help would be appreciated.
thanks
-- Smitty!!!
7 replies so far
View Redoak49's profile
Redoak49
4355 posts in 2597 days
#1 posted 10-13-2018 05:51 PM
Did you look at the tension setting.
If no one can help you here, post on Scroll Saw Village.
View JRsgarage's profile
JRsgarage
367 posts in 1117 days
#2 posted 10-13-2018 05:59 PM
Perhaps your machine fell out of alignment. Use the rear knob to get it back to parallel with the table..that should raise or lower the mount
-- “Facts don't care about your feelings.” ..., Ben Shapiro
View MrUnix's profile
MrUnix
7597 posts in 2807 days
#3 posted 10-13-2018 06:14 PM
My bet is the tension adjustment as well… I don’t have the same saw, but I know that on more than one occasion on mine, usually after a blade breakage, I forget to release the tension lever and the same thing happens (appears the blade is too short).
woodsmithshop
#4 posted 10-13-2018 06:40 PM
the tension lever has been released, I’ll check the alignment, don’t know if the tension knob can be turned back that much or not.
thanks
-- Smitty!!!
View tomsteve's profile
tomsteve
988 posts in 1827 days
#5 posted 10-13-2018 10:44 PM
the tension knob on an EX16 moves the front of the arm about a half inch or so in one turn . id imagine on the ex 21 or 30 its even more.
had the problem on my EX16. i hadnt been paying attention to the mark on the tension knob. it was turning a little bit over time and eventually i barely had any blade in the clamp. simple one full turn and back in business.
woodsmithshop
#6 posted 10-14-2018 12:58 PM
it is amazing how something can get out of adjustment while not being used for a long time, thank you guys for shaking the cob webs out, (out of my head) all it was, was the tension knob out of adjustment, I still don’t get how that happens, it was working fine the last time I used it. Oh well, it must be the workshop gremlins or something like that.
all it took was a small adjustment on the tension knob and all was fine.
Thanks guys.
-- Smitty!!!
tomsteve
#7 posted 10-14-2018 03:04 PM
good to hear!
when ya find them gremlins, have them return my pencils! :)
