Anyone have a Jet Mini Lathe motor for sale?
« back to Woodturning forum
Forum topic by MUST58GT posted 10-13-2018 01:11 PM 881 views 0 times favorited 8 replies Add to Favorites Watch
View MUST58GT's profile
MUST58GT
108 posts in 837 days
10-13-2018 01:11 PM
Topic tags/keywords: jet mini lathe motor jml-35
I need to replace the motor on my Jet Mini Lathe. Unfortunately, Jet is out of stock and won’t have any motors till January. My mini lathe model# is 1014 but am pretty sure a 1015 motor will work also.
The Jet Tools part number is JML-35.
So, am hoping to find someone that has upgraded to variable maybe and might be interested in selling their original motor.
Happy to pay via PAYPAL or whatever online payment service you prefer.
Thanks!
-- Richard, Austin TX - "Every repair job is really just an upgrade oppty in disguise!"
8 replies so far
View Wildwood's profile
Wildwood
2794 posts in 2745 days
#1 posted 10-13-2018 08:07 PM
Have read both good and bad reviews on this motor, could not get the 95 reviews listed to come up.
https://www.pennstateind.com/store/TCLVSKIT.html
I would hold off and buy the Jet motor from them, if cannot wait try this place.
https://www.ereplacementparts.com/jet-jml1014i-708375-mini-lathe-parts-c-32652_32854_33061.html
-- Bill
View Lazyman's profile
Lazyman
4546 posts in 1998 days
#2 posted 10-14-2018 12:29 AM
I’ve added the PSI motor in the link above to my mini lathe and it works okay. It occasionally overheats and shuts down when I really push it hard turning a large bowl but otherwise I really like the variable speed capability. A lot nicer than constant belt changes. BTW, if you sign up for their email sale notifications, they usually send you a 10 to 15% off coupon code for your first order so it will be even cheaper.
MUST58GT
#3 posted 10-14-2018 02:12 AM
- Lazyman
Thanks. I took the OEM motor into a local electric motor shop this morning to determine root cause. They’ll definitely know whether it’s salvageable and for how much $$. If that doesn’t pan, I’ll be looking much more seriously at the PSI VS option.
In the mean time, you didn’t keep your old motor, did you? :)
View JayT's profile
JayT
6364 posts in 2822 days
#4 posted 10-14-2018 02:39 AM
I purchased the PSI kit and was not happy with it at all. Ended up sending it back and returning to the factory setup. I posted a review here on LJ. Please read it completely, especially the part where PSI censors reviews to keep the rating on that kit high.
-- https://www.jtplaneworks.com - In theory, there is no difference between theory and practice. In practice, there is.
View gleasoncraftworks's profile
gleasoncraftworks
33 posts in 1845 days
#5 posted 10-14-2018 02:53 AM
Try contacting this guy. The price is reasonable.
https://spacecoast.craigslist.org/tls/d/jet-mini-lathe-motors/6721349017.html
Lazyman
#6 posted 10-14-2018 03:06 AM
In the mean time, you didn t keep your old motor, did you? :)
- MUST58GT
I did but I am thinking about using it to make a small belt grinder.
MUST58GT
#7 posted 10-16-2018 01:14 PM
Thanks all for the input. I took the motor to a local electric motor shop and they called back yesterday to tell me the capacitor is shot. They replaced the cap (25uf, 250vac) and the motor seems to work fine now. Total cost of repair is definitely less than a new motor.
BTW – After looking and communicating with several Jets parts distributors for a few days, I did eventually find one of their parts distributors that has two in stock. As far as I can tell, those are the only two JML-35 motors available on the planet till Jet gets their shipment from Taiwan.
Lazyman
#8 posted 10-16-2018 01:19 PM
Doh! I didn’t think to recommend checking or replacing the capacitor. It is usually the first thing to check when a motor just suddenly stops working. It is usually a cheap fix and one you can often do yourself. You can usually find a comparable capacitor on Amazon for under $20.
