Plywood; now and then
Forum topic by MrRon posted 10-12-2018 10:10 PM 796 views 0 times favorited 20 replies Add to Favorites Watch
View MrRon's profile
MrRon
5813 posts in 3855 days
10-12-2018 10:10 PM
Plywood used to be manufactured to even fractional sizes, such as 1/4”, 1/2”, 3/4” etc. At some point, the face and back veneers got thinner and thinner making the present plywoods a 1/32” less making it 23/32” instead of 3/4”. The same went for all other sizes. Why didn’t they adjust the core veneers thicknesses in order to maintain 3/4”??? Working with an even 3/4” thickness makes woodworking much easier. In a world that runs on standardization, plywood seems to have dropped the ball. Chinese plywood appears to be made without a standard. I have measured Chinese plywood and the thickness can vary quite a bit; enough to make a dado joint too tight or too loose.
20 replies so far
View BroncoBrian's profile
BroncoBrian
875 posts in 2570 days
#1 posted 10-12-2018 10:17 PM
You are correct sir. Dados and plywood require adjustments even within the same sheet if you want precision. I am noticing more air pockets in plywood lately.
-- A severed foot is the ultimate stocking stuffer.
View Rayne's profile
Rayne
1300 posts in 2151 days
#2 posted 10-12-2018 10:28 PM
Even the higher quality Baltic Birch isn’t 3/4”, but much closer than most of the other plywoods in my area. Even 23/32” isn’t really 23/32”...sad but true.
View Richard Lee's profile
Richard Lee
260 posts in 1387 days
#3 posted 10-12-2018 10:33 PM
Gotta save a penny or 2 somehow.Soon a 2×4 will be 1 1/4 by 3
Never ends.
View lumbering_on's profile
lumbering_on
578 posts in 1101 days
#4 posted 10-12-2018 10:35 PM
Can’t speak to the Chinese plywood, and I’d rather it didn’t exist. However, there is a major cost advantage with making plywood a bit thinner.
View johnstoneb's profile
johnstoneb
3131 posts in 2784 days
#5 posted 10-12-2018 10:41 PM
Plywood went metric.
-- Bruce, Boise, ID
View ArtMann's profile
ArtMann
1462 posts in 1428 days
#6 posted 10-13-2018 02:02 AM
Baltic Birch is called that because it is imported from the Baltic countries of Eastern Europe. It has always been manufactures to metric sizes.
I have something of a historical perspective on plywood because I started building stuff with it around 1975. It was not the nominal size then either. I salvaged some plywood for shop cabinets that came out of a 1950’s grocery store. That material was a true 1/2 or 3/4 inch as best I could tell. I still have a cabinet made out of it.
Even the higher quality Baltic Birch isn t 3/4”, but much closer than most of the other plywoods in my area. Even 23/32” isn t really 23/32”...sad but true.
- Rayne
MrRon
#7 posted 10-13-2018 02:28 AM
True Baltic birch comes only in 60” x 60” sheets and is measured in metric. A 4×8 sheet of birch is not Baltic birch.
View Dark_Lightning's profile
Dark_Lightning
3770 posts in 3720 days
#8 posted 10-13-2018 02:35 AM
- MrRon
Sure looks like it though, with the two outside plies the same thickness as the other plies, and not some 1/(whatever you can see through) thickness veneer. You may only be seeing it in 5’X5’ sheets where you are, but when I worked for LADC (Skunk Works) we bought it in 5’X10’ sheets (well, the metric equivalent thereof) in many thicknesses.
-- Steven.......Random Orbital Nailer
View Aj2's profile
Aj2
2658 posts in 2409 days
#9 posted 10-13-2018 04:48 AM
I don’t buy plywood very often but when I do I get Baltic birch. I really like the way it smells. The place I buy it from has it unfinished and finished. The unfinished stuff seems nicer.
-- Aj
View Woodknack's profile
Woodknack
13027 posts in 2991 days
#10 posted 10-13-2018 03:48 PM
My house was built in ‘69, my shop sometime after, both built with true fractional plywood. Also the 2x lumber is actual size, 2×8 is 2” by 8”.
View PropmakerLA's profile
PropmakerLA
15 posts in 622 days
#11 posted 10-13-2018 04:56 PM
A lot of the products we use come from china. We call it 3/4 MDF but its stamped 18mm, what we call 1/2in is really 12mm. So I guess a lot depends on where the products are manufactured.
View Kazooman's profile
Kazooman
1413 posts in 2564 days
#12 posted 10-13-2018 05:09 PM
- MrRon
True. What always struck me as odd is the size of the sheet is in Imperial inches and the thickness is in metric millimeters. Talk about mixing apples and oranges!
View 000's profile
000
2859 posts in 1511 days
#13 posted 10-13-2018 05:42 PM
- MrRon
- Kazooman
Damn, my lumber yard has been lying to me for years. What a fool I am.
MrRon
#14 posted 10-13-2018 08:09 PM
- MrRon
Sure looks like it though, with the two outside plies the same thickness as the other plies, and not some 1/(whatever you can see through) thickness veneer. You may only be seeing it in 5 X5 sheets where you are, but when I worked for LADC (Skunk Works) we bought it in 5 X10 sheets (well, the metric equivalent thereof) in many thicknesses.
- Dark_Lightning
You were probably getting a special order due to commercial purpose. Did you work with Kelly Johnson?
View 000's profile
000
#15 posted 10-13-2018 08:44 PM
https://www.wolstenholme.com/plywood-products/baltic-birch/
Russian Birch plywood is uniquely manufactured with multiple ply’s of Birch veneer, used uniformly, throughout the panel. Each layer of birch veneer is peeled at 1.3mm or 1.5mm thickness giving the panel a multi-ply edge that is both aesthetically attractive and offers unmatched strength and stability. Birch plywood from Russia has been available in the United States for over fifty years, and still today, goes by the trade name of Baltic Birch. Historically, only available in 5’x5′ sheets, today Russia has expanded production to include numerous other formats, such as 4’x8′ and 10’x5′ and 10’x4’.
It doesn’t have to be special ordered. You just have to have a descent lumber company that stocks it.
