Contact Cement and MDF
Forum topic by dakremer posted 10-09-2018 12:44 AM 1313 views 0 times favorited 14 replies Add to Favorites Watch
View dakremer's profile
dakremer
2748 posts in 3942 days
10-09-2018 12:44 AM
I’m building some MDF cabinet doors. My plan is to glue 1/4 MDF (rails and stiles) onto 1/2 MDF base. I don’t have a vacuum bag clamping system, which would obviously be the best option. I’m thinking about just using some Contact Cement, to make the glue-up super easy – What are your thoughts on this? Any reason not to do this? Think it’ll be strong enough or hold up over time? These doors will be painted.
-- Hey you dang woodchucks, quit chucking my wood!!!!
14 replies so far
dakremer
#1 posted 10-09-2018 12:52 AM
Besides the glue-up, I’m also a little concerned about installing hinges in the MDF…
View Rich's profile
Rich
5879 posts in 1440 days
#2 posted 10-09-2018 01:17 AM
Just plain old Titebond will work fine. Get a brayer or use a brush so you can spread it evenly and use another piece of 1/2” MDF as a caul on the top to make sure it clamps evenly. Be sure to glue it up a little oversized and then trim it when it’s glued to be the final dimension and square.
Hinges will be fine as long as you’re screwing into the face of the MDF. Going into the core through the side is weaker.
View lumbering_on's profile
lumbering_on
578 posts in 1341 days
#3 posted 10-09-2018 01:22 AM
Depends on what you mean by ‘easy’. Contact cement is a great way to glue mdf panels, as long as you know how to do it correctly. I’ve had my ‘fun’ with contact cement in the past, so just make sure you plan ahead because once it touches, it’s all over.
My suggestion would to make the frames a little over sized, and then use a router to clean up the inside and outside.
dakremer
#4 posted 10-09-2018 01:28 AM
Ok – I just made a door. It went really well! seems like it’ll work just fine. Now just need to make about 10 more…..
View tyvekboy's profile
tyvekboy
2045 posts in 3864 days
#5 posted 10-09-2018 01:49 AM
Just a tip I learned when working with contact cement. After you get the contact cement spread on both surfaces, use a piece of TYVEK as a slip-sheet. Just place it on one of the glued surfaces.
This will allow you to position it where you want before you pull out the slip-sheet. Based on what you are doing, I would use strips of TYVEK. Then you can pull the slip-sheet of each side of the square frame out after positioning it.
Hope this helps.
-- Tyvekboy -- Marietta, GA ………….. one can never be too organized
lumbering_on
#6 posted 10-09-2018 01:55 AM
Hope this helps.
- tyvekboy
Where were you when I needed this advice? ;)
dakremer
#7 posted 10-09-2018 02:08 AM
What I did was line up one side with a flat edge. Once it was all bonded, I trimmed the other ends, and then came back and trimmed that lined up edge. Everything came out nice and square – pretty easy build actually! Just hope it holds up over time!
lumbering_on
#8 posted 10-09-2018 02:24 AM
It will hold, trust me, I have some cladding I did for my parents 15 years ago that’s still holding up well. Glad it went better than my first attempt with it. I didn’t plan very well and I ended up redoing a lot of work.
View GR8HUNTER's profile
GR8HUNTER
7787 posts in 1563 days
#9 posted 10-09-2018 02:25 AM
why not just use popular with MDF panel ? just curious as to what benefits you think you night have with all MDF :<))
View Jim Jakosh's profile
Jim Jakosh
25186 posts in 3956 days
#10 posted 10-09-2018 02:27 AM
I’d use Titebond III and put weights on the outer frame until the glue sets up. I’d be concerned with hinges in MDF especially if the doors are to be used quite a bit, But if you must, after aligning the hinges and screwing them in place, I’d take all the hinges off and put Titebond II in the screw holes with a tooth pick and let it make a harder seat for the screws to give them a chance of holding better.
Using contact cement, you have to make perfect alignment when the two meet because there is no chance for movement once they touch. If you have a way to do that, it will work good too. I always like to roll the piece with a weighted roller when using contact cement to insure full contact everywhere on the part.
View cracknpop's profile
cracknpop
446 posts in 3200 days
#11 posted 10-09-2018 02:28 AM
My concern with contact cement and MDF is how it will hold up over time. I used contact cement between Formica sheet and MDF for extensions to my table saw. Glued Formica to both sides. A year or two later, Formica sections began to fall off. The glue didn’t fail, the top surface fibers of MDF released.
Of course, your application being painted doors inside a home where the humidity levels are fairly stable may make a huge difference over my table saw extensions in my woodshop and humidity swings during Summers in Indiana.
-- Rick - I know I am not perfect, but I will keep pressing on toward the goal of becoming all I am called to be.
dakremer
#12 posted 10-09-2018 02:49 AM
- GR8HUNTER
I’m in a time crunch. Trying to get these done before little baby kremer comes in a month. Also, baby Kremer will probably destroy these within a few years, so I don’t want to put a ton of money in them – I can always remake them. As far as other benefits – the MDF is more stable and won’t warp – its dead flat. It’s also super easy to paint. Also they way I made them, the stiles and rails will never “crack” because they are one solid piece.
View mtnwalton's profile
mtnwalton
80 posts in 1877 days
#13 posted 10-09-2018 03:09 AM
About 15 years ago I built a two door cabinet (rolling with 8” casters) with 10 drawers behind the doors. At the time I had more MDF than funds so the bulk of the cabinet was in MDF. Drawers were plywood. The hinges held up well under tough abuse from many volunteers. Unit was transported in and out of shops and backstage areas for stage productions fairly frequently.
View Richard's profile
Richard
11309 posts in 3884 days
#14 posted 10-13-2018 09:22 PM
- GR8HUNTER
I m in a time crunch. Trying to get these done before little baby kremer comes in a month. Also, baby Kremer will probably destroy these within a few years, so I don t want to put a ton of money in them – I can always remake them. As far as other benefits – the MDF is more stable and won t warp – its dead flat. It s also super easy to paint. Also they way I made them, the stiles and rails will never “crack” because they are one solid piece.
- dakremer
That’s the way to go!
Rick S.
-- Richard (Ontario, CANADA)
