32mm cabinetry system
Forum topic by Andrew714 posted 10-08-2018 05:53 PM 902 views 0 times favorited 23 replies Add to Favorites Watch
View Andrew714's profile
Andrew714
56 posts in 1882 days
10-08-2018 05:53 PM
Topic tags/keywords: cabinetry 32mm system
I am considering switching from my normal day job to cabinetry, and I have a couple questions for other professional cabinetry makers, especially those that build cabinets using the 32mm system.
My plan (at least to start with) is to make cabinets with the 32mm system, using a number of Festool tools, most notably their LR-32 rail system. The standard cabinet height though (I believe that’s 34-1/2”), doesn’t work out to an even increment of 32mm, and I think the best 32mm increment puts it 12mm lower than 34-1/2”. Does anyone know if this causes any major issues? Since it would be lower, I think it’s safe to say that it wouldn’t interfere with locations for outlets and switches, which would be installed based on cabinetry standards, rather than the designs from the cabinet maker.
Second question- My preference would be to have the toe kick integrated as part of the cabinet box, rather than adding risers after the box is built. Based on the 32mm system, this would make the toe kick 96mm tall, and I figure an even 75mm deep is probably fine. Any thoughts on this? I’m not sure how it’s normally done, or if there are any drawbacks to making the toe kick any shorter than 4”.
There may be other considerations that I’m not aware of yet as well, so I appreciate any input you can give, even if it’s not on a topic I have mentioned yet.
Thanks,
Andrew
23 replies so far
View ArtMann's profile
ArtMann
1462 posts in 1423 days
#1 posted 10-08-2018 05:59 PM
Your customers won’t care what equipment you will be using. If they want cabinets at some arbitrary height and width, you better be prepared to build them that way, regardless of your preferences.
Andrew714
#2 posted 10-08-2018 06:03 PM
Your customers won t care what equipment you will be using. If they want cabinets at some arbitrary height and width, you better be prepared to build them that way, regardless of your preferences.
- ArtMann
I definitely get that part of it, which is why I want to get an idea for what is normally done. For example, if the 32mm system could be useful for a specific scope of cabinetry, but can be limiting overall, maybe I just abandon that.
View bondogaposis's profile
bondogaposis
5605 posts in 2958 days
#3 posted 10-08-2018 06:48 PM
Get a hold of a reference book, where you can get the standards for cabinetry. A lot of this stuff has been worked out, no sense re-inventing the wheel. Here is one I recommend, The Complete Kitchen Cabinetmaker, by Robert Lang. In he covers both face frame and frame less cabinets. You can get it here.
-- Bondo Gaposis
View waho6o9's profile
waho6o9
8812 posts in 3183 days
#4 posted 10-08-2018 07:03 PM
Appliances need to be considered as well. Good luck on your future endeavors.
Andrew714
#5 posted 10-08-2018 07:05 PM
- bondogaposis
I actually already have that book, thanks for the tip. It’s a good book, and has been pretty helpful.
Andrew714
#6 posted 10-08-2018 07:09 PM
- waho6o9
Thanks, that’s a very good point. Having the cabinets 12mm lower could be a critical mistake when it comes time to install a dishwasher. I think that settles it- I just need to build cabinets to the standards we have in the US. I’d hate to build a kitchen full of cabinets, only to find a major problem at the time of installation.
waho6o9
#7 posted 10-08-2018 07:19 PM
You’re welcome.
Story sticks are helpful:
https://www.youtube.com/watch?v=D2fiIDapLOU&t=25s
Bob Rozaieski Fine Woodworking
Published on Jan 29, 2014
http://lumberjocks.com/topics/255481
View jerkylips's profile
jerkylips
495 posts in 3177 days
#8 posted 10-08-2018 08:10 PM
one other thought – lower cabinets should be pretty standard (although when we built our house, they gave us the option to do standard or “comfort height” lowers in the bathrooms – about 2” taller), but uppers are going to vary based on ceiling heights. I don’t think there’s any such thing as a standard height anymore..
View Pompeio's profile
Pompeio
9 posts in 797 days
#9 posted 10-08-2018 08:51 PM
Wall cabinet height 960 mm
Base cabinet height 768 mm
You need to ensure that the mm are exactly divisible by 32 or you will have problems using the LR32.
Easier if you make the toe kick separate.
Andrew714
#10 posted 10-08-2018 08:58 PM
- Pompeio
What is normally done for a separate toe kick? Is that normally the add-on legs, whether they are hidden or visible, or do people sometimes make some sort of riser out of plywood, inexpensive lumber, etc?
Pompeio
9 posts in 797 days
#11 posted 10-08-2018 09:26 PM
Consider 3/4” plywood 4” wide and rip to the desired length <——width=”true”> plywood and then just cover the face with plywood.
Then crosscut the
View Rich's profile (online now)
Rich
5141 posts in 1196 days
#12 posted 10-08-2018 11:11 PM
- Pompeio
- Andrew714
A separate toe kick will make a big difference if you’re using 60×60 baltic birch since you can get four 30” tall side panels out of a sheet and still have a 34” tall cabinet before the top. An integral toe kick will make panels too tall for that.
waho6o9
#13 posted 10-08-2018 11:23 PM
Joel Ketner has a 32mm system that may be helpful.
http://www.cabsystems.com/KISSII/KIIrivDe-mail.pdf
runswithscissors
3081 posts in 2632 days
#14 posted 10-09-2018 12:02 AM
Actually, the wheel has been reinvented many times. That’s why you can get tubeless tires that last 60k or more on mag wheels. If not so, we’d still be using sawed off log ends for wheels.
bondogaposis
#15 posted 10-09-2018 06:31 PM
So true, but unless he uses standard cabinet dimensions to accommodate appliances he is going to have to reinvent the dishwasher.
-- Bondo Gaposis
