Update on plywood bistro table tops - thanks all for your help!
Forum topic by Neophyte posted 10-08-2018 03:06 PM 669 views 0 times favorited 4 replies Add to Favorites Watch
View Neophyte's profile
Neophyte
34 posts in 2966 days
10-08-2018 03:06 PM
Topic tags/keywords: bistro table tops glueing plywood
Friends,
This is an update to my post back in July: http://lumberjocks.com/topics/282226
In short, I got advice on how to put together some plywood table tops by glueing two sheets without warping. The client wanted 1.5” thick so I glued two 3/4” together. I chose baltic birch for this project for strength and to avoid using edge molding. I looked into BB thicker than 1” (not available here) and Appleply (also unavailable and prohibitively expensive). I made a total of 15 table tops combining the recommendations I got here and adapting them to my garage shop. I glued two table tops at a time using TB-II and for some Liquid Nails Heavy Duty (on a recommendation of someone who works with plywood). I used a roller to spread the glue. Some screws, clamps and weight for 24 hours. The one on the top is finished, the one on the bottom being glued.
They came out straight and flat. On to sanding
priming with BIN and three coats of BM Advance using a microfiber small roller. Last, GF High performance flat sprayed with a HVLP Fuji system.
This is how they look in the restaurant
Thanks to all of you who helped with this!
Marc
-- Marc, NY
View Desert_Woodworker's profile
Desert_Woodworker
1975 posts in 1824 days
#1 posted 10-08-2018 07:03 PM
Nice job
-- Desert_Woodworker
View BroncoBrian's profile
BroncoBrian
875 posts in 2568 days
#2 posted 10-08-2018 07:07 PM
Those look great.
-- A severed foot is the ultimate stocking stuffer.
View waho6o9's profile
waho6o9
8812 posts in 3186 days
#3 posted 10-08-2018 07:22 PM
Great results good job!
View Aj2's profile
Aj2
2651 posts in 2407 days
#4 posted 10-08-2018 08:47 PM
Good Job looks great.
-- Aj
