Porter cable 7518 fixed base twist depth for table mount
Forum topic by willhime posted 10-07-2018 02:34 PM 1169 views 0 times favorited 4 replies Add to Favorites Watch
View willhime's profile
willhime
146 posts in 2147 days
10-07-2018 02:34 PM
Topic tags/keywords: jig question resource tip trick router
My old Bosch fixed base 1617 EVS router I have in my table just quit the other day. In a hurry I ordered the most commonly recommended beefy fixed base I could find. The porter cable 7518 fixed base. After opening it and seeing that the depth adjustment requires you to rotate the base I realized I might have been to hasty with my purchase. If I have to rotate this monster to adjust depth that rules out a router lift plate and also I’ll have its huge power cord rotating around my enclosed table cavity. Is there something I’m not realizing about how to use this in my table or am I correct in thinking this thing will be a nuisance to depth adjust every time I use it ?
-- Burn your fire for no witness
View Rich's profile (online now)
Rich
5149 posts in 1198 days
#1 posted 10-07-2018 03:07 PM
That type of motor is what is required for lifts like the JessEm and others in its class. You don’t use the base; the motor is clamped in the lift. Very solid. If you have the funds it’s the way to go.
willhime
#2 posted 10-07-2018 03:45 PM
I am in fact looking to buy a lift plate. The most attractive option is jessem’s router lift II. Obviously because of the price – $224 with insert rings but it doesn’t say anywhere that it’ll fit the 7518, leaving me in the $300-400 range. Is there a good lift plate that’ll fit it that’s not so pricey or did I buy myself into a corner ?
Rich
#3 posted 10-07-2018 03:58 PM
Maybe others will chime in. I haven’t researched all of the choices out there. I bought the JessEm Mast-R-Lift II and have no regrets. I know the Woodpecker lift is quite popular as well.
View JRsgarage's profile
JRsgarage
367 posts in 1118 days
#4 posted 10-07-2018 04:16 PM
I think most lifts will state which routers will fit but the ones that support the 7815 or any of the bigger motors will be little more money due to more heft. Also, make sure the plate will fit your current router table.
I have my 690 fixed base on a plexiglass plate for portability and adjust by twisting. It works fine….actually kinda helps for fine adjustments but the cord does get in the way.
-- “Facts don't care about your feelings.” ..., Ben Shapiro
