Not quite a cabriole
Forum topic by GatiD posted 10-07-2018 01:52 PM 488 views 0 times favorited 9 replies Add to Favorites Watch
View GatiD's profile
GatiD
4 posts in 471 days
10-07-2018 01:52 PM
Topic tags/keywords: cabriole
So I have a set of what look like incomplete cabriole legs, in that they don’t have an upper stem, nor wings,and the back is flat with threaded inserts. I can’t find any designs/ plans for how to make a frame for them. I’m hoping someone may have a suggestion as to how to make a simple footstool frame that makes sense given their odd set up.
9 replies so far
View bilyo's profile
bilyo
959 posts in 1707 days
#1 posted 10-07-2018 02:45 PM
You need to be more specific. A picture or two would help a lot. What do you mean by “incomplete”, “make a frame”, and “odd set up”?
View bondogaposis's profile
bondogaposis
5605 posts in 2955 days
#2 posted 10-07-2018 06:21 PM
Yeah, pretty hard to envision this without a picture.
-- Bondo Gaposis
GatiD
4 posts in 471 days
#3 posted 10-07-2018 08:19 PM
Absolutely! Here are a few, and thanks for replying!
View lumbering_on's profile
lumbering_on
578 posts in 1094 days
#4 posted 10-07-2018 08:41 PM
They sort of look like the legs on an old chair my parents have, but they attache on the top of the leg. Where did you find them?
GatiD
4 posts in 471 days
#5 posted 10-07-2018 08:52 PM
My wife bought them on ebay. Most pics I see of similar legs show these with square stems that come out the top and that are tenoned to a frame. These seem to be emulating that but have joint connections on the back. But I have not yet found any kind of design or pattern that would incorporate legs like this with that way of attaching to a frame. I seem to keep tackling projects that don’t have ready made plans…
View CWWoodworking's profile (online now)
CWWoodworking
547 posts in 783 days
#6 posted 10-07-2018 08:53 PM
They have a flat side to attach skirts to. You could make corner blocks and use the threaded insert for extra strength.
Personally I would just pocket hole it together and use a corner block with bolt.
View OG51's profile
OG51
157 posts in 715 days
#7 posted 10-07-2018 08:56 PM
Hopefully I am understanding the question correctly. The design uses a brace that is diagonal to the frame sides to attach the legs (see bad drawing). Once you have the frame you can attach a top with whatever technique you want. I used this type of joinery on some of my pieces so I don’t have to do any mortises.
http://lumberjocks.com/projects/361937
Rockler sells the hardware but there are many companies that also sell them.
https://www.rockler.com/surface-mount-corner-brackets-for-table-aprons?sid=V9146?utm_source=google&utm_medium=cpc&utm_term=&utm_content=pla&utm_campaign=PL&gclid=EAIaIQobChMIhcrZtZv13QIVBQppCh1VFwBfEAQYASABEgKCs_D_BwE
lumbering_on
#8 posted 10-07-2018 09:05 PM
CW’s idea makes a lot of sense. Not really much you else you could do with it, short of attaching a tenon to the back and then using it to mimic a real cabriole leg.
GatiD
4 posts in 471 days
#9 posted 10-09-2018 01:22 PM
Thank you for the replies, I do think that the mounting hardware would be the easiest way to go. I wasn’t sure if I needed to make a box and then figure out how to attach, or if I should integrate the legs into the frame of the box and this clears that right up.
