Grinder Lathe
« back to Woodturning forum
Forum topic by Plutosson posted 10-05-2018 11:45 AM 689 views 0 times favorited 6 replies Add to Favorites Watch
View Plutosson's profile
Plutosson
10 posts in 759 days
10-05-2018 11:45 AM
Does anyone make a lathe center drive that will screw onto a 1/2” bench grinder arbor?
View Nubsnstubs's profile
Nubsnstubs
1732 posts in 2610 days
#1 posted 10-05-2018 02:44 PM
That question has my curiosity in motion. What size CONTRAPTION are looking for, and what do you need something like that for? There are things that can be used, but I personally need more info than your question poses. ............. Jerry (in Tucson)
View Wildwood's profile
Wildwood
2899 posts in 3014 days
#2 posted 10-05-2018 03:38 PM
Is this what you are looking for? Not many sharpen their tools on the lathe anymore but certainly doable.
https://www.highlandwoodworking.com/lathearbor2mt.aspx
-- Bill
View Kenbu's profile
Kenbu
40 posts in 2760 days
#3 posted 10-05-2018 09:49 PM
Check out the mini-lathe article in Shopnotes #73. There’s a page about DIY drive centers that may give you some ideas. https://archive.org/stream/ShopNotesMag/ShopNotes%20%2373%20%28Vol.%2013%29%20-%20Mini%20Lathe#page/n21
Ken
Plutosson
#4 posted 10-06-2018 01:43 PM
Thanks Ken. That’s where I was going with this. I had a similar idea but this really articulates the “how to”. I already have the coupling nut, I just need to pick up the threaded bar and get cutting and grinding.
Wildwood
#5 posted 10-08-2018 07:08 PM
Not sure what you want to do but after reading Ken’s link going need lot more hardware.
What is the max RPM’s of the grinder going to use? Are you talking a about 1/2” x 12 or 13 TPI or larger grinder spindle?
While might find a malleable steel coupling to fit the thread of your grinder spindle not sure that’s the way to go about it! That homemade drive center doesn’t have much tensile strenght.
Good luck with it!
-- Bill
Plutosson
#6 posted 10-08-2018 08:24 PM
Thanks Bill. I have a coupling nut. I’ll need the threaded rod to form the center point (although the tolerances are a bit worrying). I’m going to start by lathing wood and plastics. For a metal lathe I think I would be better off buying one made for it.
I don’t plan on it being an all the time thing so a homemade set up should work ok. Should I say. We’ll see and I’ll try to let the group know.
Thanks again. This is one of the best groups I’ve ever signed up with.
