Newb question about cutting plywood
Forum topic by AliceAforethought posted 10-04-2018 11:01 PM 694 views 0 times favorited 10 replies Add to Favorites Watch
View AliceAforethought's profile
AliceAforethought
16 posts in 1880 days
10-04-2018 11:01 PM
Hello All,
Let’s say i have a piece of plywood 40×40, and want to rip one side so that the new dimensions are 40×38. On my small contractor saw, would it be safe to cut the 2 inches on the side between the blade and the fence? There isn’t enough table width to accommodate a piece that large to rip the 2 inches on the other side of the blade. Thanks for your replies.
10 replies so far
View Rayne's profile
Rayne
1300 posts in 2149 days
#1 posted 10-04-2018 11:12 PM
That shouldn’t be a problem as long as you have control of the 2” piece as well when you cut it. (like have 2 grrippers to push it along to have total control). Also make sure to take into account the blade kerf because you want to keep the larger piece rather than the cut off.
View Richard's profile
Richard
11309 posts in 3642 days
#2 posted 10-04-2018 11:32 PM
That shouldn t be a problem as long as you have control of the 2” piece as well when you cut it. (like have 2 grrippers to push it along to have total control). Also make sure to take into account the blade kerf because you want to keep the larger piece rather than the cut off.
- Rayne
Totally Agree with Rayne.
Rick S.
-- Richard (Ontario, CANADA)
View mathguy1981's profile
mathguy1981
94 posts in 514 days
#3 posted 10-04-2018 11:54 PM
+1 ^^ above.
The dangerous part will be when you’re stretched out over the saw to cut the last 6 inches. Recommend mocking up an outfeed table at the same or about 1/2 inch lower to support the large piece of plywood you’re keeping as you extend yourself over the table. I’ve often used heavy things around the shop to help with outfeed.
-- Two thumbs and counting
View Fresch's profile
Fresch
460 posts in 2530 days
#4 posted 10-05-2018 12:11 AM
I would clamp a guide on and use a circular saw.
View lumbering_on's profile
lumbering_on
578 posts in 1100 days
#5 posted 10-05-2018 12:51 AM
By yourself? I wouldn’t do it with a small saw, unless you’ve built a table around it. Better to use a circular saw. If you have someone that can help you with the off cut, then as long as both of you know how to do it, then you will be fine. The operative phrase part being that you both have to know how to handle the cut.
AliceAforethought
#6 posted 10-05-2018 01:12 AM
Although I have a table built around it, I think that piece of plywood is just too big for one person to handle. I’ll go the circular saw route. Thanks for the replies.
View MrRon's profile
MrRon
5812 posts in 3853 days
#7 posted 10-06-2018 02:44 PM
I’ve cut 4×8 sheets on my saw. The good thing is a 4×8 sheet is heavy and possible kickback is minimized.
View RobinDobbie's profile
RobinDobbie
147 posts in 2345 days
#8 posted 10-06-2018 03:12 PM
Ideally it’s good to have a little more than half of the board supported during and after it’s been cut. You might benefit from going through the motions with the saw off and blade down to see if you’re going to have major problems.
I agree a circular saw might be the way to go.
AliceAforethought
#9 posted 10-06-2018 04:55 PM
Yeah, I did the cuts with a circular saw. No need to risk injury when an alternative way to cut is available.
MrRon
#10 posted 10-07-2018 03:51 PM
I cut 4×8 sheets on an 8” tilt table saw back in the 50’s when I was young, dumb and stronger than now. Today I still cut 4×8 sheets on my 10” cabinet saw, but I now make sure there is adequate support for the offcut. Nothing like experience .
