Double Sided V-Groove Router Bit?
Forum topic by pf_flyguy posted 10-04-2018 10:48 PM 517 views 0 times favorited 4 replies Add to Favorites Watch
View pf_flyguy's profile
pf_flyguy
2 posts in 2725 days
10-04-2018 10:48 PM
Topic tags/keywords: tongue and groove v-groove
I am making a bunch of Tongue and Groove Boards for exterior gates. The wood profile I am looking to achieve is:
I had hoped the Yonico 15227 Matched Tongue and Groove V-Notch Router Bit Set 1/2-Inch Shank would work and that I could just flip the boards to get the desired profile … unfortunately not
My boards are 1/2” and I have ended up doing multiple passes on the table saw at various angles to get the result I wanted.
Does anyone know of a router bit set that will achieve my desired profile?
Thanks.
View Shamb3's profile
Shamb3
39 posts in 792 days
#1 posted 10-04-2018 11:40 PM
Why do those not work?
The tongue is 1/4 inch. So wouldn’t you just adjust that part to be 1/8th of an inch above the table? Then flip the boards as you described?
View gwilki's profile
gwilki
330 posts in 2084 days
#2 posted 10-05-2018 12:57 AM
I’m with Shamb3. I have that same set from Lee Valley and I’ve made miles of tongue and groove with it. What part of it does not work for you?
-- Grant Wilkinson, Ottawa ON
View 000's profile
000
2859 posts in 1510 days
#3 posted 10-05-2018 01:18 AM
The problem is the 1/2” material.
The tongue is 1/4” then there is a lip that looks to be 1/16 (or bigger). This doesn’t leave much for the bevel
You need a set up without the lip, since your using a Yonico bit look at this one for comparison.
(you would have to set up a fence for to cut the tongue because there is no bearing)
https://www.amazon.ca/Yonico-15223-Matched-Tongue-Banding/dp/B00KZM2AII
Why are you using 1/2” material? I would think 3/4” min.?
pf_flyguy
#4 posted 10-05-2018 01:28 AM
evidently, Yonico have a “Small” V-groove set also. the tongue is 3/8 on this one
https://www.amazon.com/gp/product/B0711BJ2ZM/ref=oh_aui_search_detailpage?ie=UTF8&th=1
I will give this set a shot and see if I get better results
