Pipe Clamp Rolling
Forum topic by Randy T posted 10-04-2018 06:07 PM 624 views 0 times favorited 7 replies Add to Favorites Watch
View Randy T's profile
Randy T
38 posts in 615 days
10-04-2018 06:07 PM
Folks:
I have numerous pipe clamps that I have had for many years. They work well and are a great asset.
I recently purchased some new ones, and they are a Royal Pain In The Rear.
Whenever I try to tighten them, the clamp wants to twist on the project. It seems that the only way that I can turn the handle tighter without the clamp twisting is to put a wrench on the frame of the clamp while I am tightening the handle. This is happening even before I get any amount of pressure on the clamp.
It isn’t like it is one clamp either. I have several sets that do this. The original clamps were Pony Clamps. The new ones are a knock-off and I am not sure what they are.
Has anyone else had this problem? Any solutions that you have come up with to stop them from twisting?
Thanks for any suggestions that you can give me.
-- Randy & Corinne, R&C Creations, British Columbia, https://www.etsy.com/ca/shop/RccreationsCanada
7 replies so far
View bilyo's profile
bilyo
962 posts in 1712 days
#1 posted 10-04-2018 09:08 PM
My first thought is that the machining of the threads is not very smooth. Maybe you could first try some lubrication. If that doesn’t work, take a close look for roughness in the threads. Perhaps you can smooth it up with a small file. If there is a lot of roughness, maybe putting some abrasive paste on the threads and running them back and forth several times would help.
View lumbering_on's profile
lumbering_on
578 posts in 1100 days
#2 posted 10-04-2018 09:24 PM
I agree with bilyo.
It sounds like the force is being converted into torque rather than the clamping pressure you need. The only way I see this happening is that the screw is catching on threads.
View Richard's profile
Richard
11309 posts in 3642 days
#3 posted 10-04-2018 11:35 PM
I agree with bilyo.
- lumbering_on
Agree!
Rick S.
-- Richard (Ontario, CANADA)
13694 posts in 3951 days
#4 posted 10-04-2018 11:45 PM
sometimes the adjustable clamp face is not flat
and has a high spot where the screw goes to it
it can make the clamp caul face pivot on this point
also can leave a dimple in the work edge
if that might be the case
take the face and file it flat
bilyo
#5 posted 10-05-2018 03:30 PM
- patron
That’s a good suggestion also. After filing off the extreme high spots, I have put wood pads on my pipe clamp faces setting them in a bed of epoxy. That flattens them and provides a bit of cushioning to help them grip a bit better.
View Nubsnstubs's profile
Nubsnstubs
1663 posts in 2340 days
#6 posted 10-05-2018 03:37 PM
Put the clamp head on the pipe with a wrench, tighten as tight as you can, then drill a hole through the clamp and pipe, Insert a shortened nail into the hole, head side out of course, and bend the nail inside the pipe such that it can’t come out. Problem solved. Did that about 30 years ago to most of my Pony clamps. Wish I’d done all of them…......... Jerry (in Tucson)
Randy T
#7 posted 10-05-2018 05:09 PM
Folks:
Thanks for your suggestions. I will give them a try.
Jerry: The clamp spinning on the pipe isn’t the problem. It is the whole bar and clamp wanting to spin off the work piece. Holding the head of the clamp by hand while tightening it doesn’t help. The only way to stop the whole thing from wanting to spin off the work piece is to hold the clamp portion with a wrench while I crank on the handle.
