Need help figuring out how to replicate this profile
Forum topic by meecect posted 10-04-2018 01:52 PM 493 views 1 time favorited 8 replies Add to Favorites Watch
View meecect's profile
meecect
3 posts in 473 days
10-04-2018 01:52 PM
Topic tags/keywords: doors routing wood exterior
I have decided to jump in the deep end and take on a big project rebuilding the doors to my house.
I want to focus on the trim around the door first. I want to replicate the original as closely as possible but I have a few questions.
-This looks like a panel but I don’t believe there are actually floating panels here. Instead, it looks like the profile is just built up. The interior edge has a carved look, and I’m not sure how to replicate that short of using a chisel. Is there a specific technique to routing an edge like that isn’t uniform across the edge?
-Should I be concerned about making the raised sections and then glueing them to a base? These are outside and will be exposed to the elements, would that cause issues longer term? It does look like how they were originally built, but I just want to know if there is a better way.
-What wood species should I be looking at for the rebuild? I will be building the doors out of the same if it matters.
Thanks in advance for any thoughts you all might have. Sorry if my questions aren’t clear…I’m more than happy to share more details/pics.
8 replies so far
View bilyo's profile
bilyo
959 posts in 1706 days
#1 posted 10-04-2018 02:34 PM
All I have some thoughts. As far as material to use; you might look into using vinyl lumber. I have no experience with it and only know about it through some TV home improvement/rehab shows I’ve seen. It looks like it is easy to work and should hold up well outdoors.
The edge profile looks like it could be made with a 45* router bit with the cut started and stopped short of the short cross pieces. The curved return (is that called a lamb’s tongue?) would require a bit of chisel and rasp work, I guess. A template might also work, but it looks like some chisel work will still be required to get the square inside cut at the base of the “lamb’s tougue” (if that is what it’s called).
Otherwise, I think I would just build up the whole component starting with a flat backer with the side verticals and cross pieces fastened/glued to it. Or, even though you think the original is not a true frame and panel, the replacement could be built that way.
Please post some photos of the finished product. Good luck.
View bondogaposis's profile
bondogaposis
5604 posts in 2954 days
#2 posted 10-04-2018 02:56 PM
I think that you are wrong about the frame a panel. I’ve used that profile on frame and panel doors quite a bit. It is done with a 45° V-groove bit and a jig on the router that is not hard to make. You make the frame and panel assembly first, then you route the profile around the inside edge. I’ll post a picture of the jig later, when I get out to the shop.
-- Bondo Gaposis
bondogaposis
#3 posted 10-04-2018 05:16 PM
Photos of the router jig for doing this, as promised. The first pic, shows the jig itself. The second 2 show it mounted on my trim router with the V-groove bit inserted. It is made of 1/4” MDF. You have to be careful not to set the bit too deep or it will gouge the panel. The depth is based on how much reveal you have between the frame and panel. For most of my purposes I use it on a 1/4” panel centered in a 3/4” frame that gives me a 1/4” reveal. Your photos show a deeper reveal I believe, and you would have to set the bit for a deeper cut.
-- Bondo Gaposis
meecect
3 posts in 473 days
#4 posted 10-04-2018 08:23 PM
Thanks, that’s great. I figured there was a simple jiog for this. I’ll check more closely to see if they actually have a panel or it is just layered up on a backer to make it look like a panel. Seems to not make any difference in the construction on the bevel though. Even if they used actual panel constuction, I may use the layered up approach..although I’m a bit worried about thermal expansion breaking the layers loose at some point.
What about wood species? Any recommendations?
Smitty_Cabinetshop
16324 posts in 3221 days
#5 posted 10-04-2018 08:43 PM
Poplar would be a good choice. Cypress if it gets wet, but know that it’s quite soft. Doug Fir, tight grain, might be a traditional option.
The flair is a stopped chamfer with lamb’s tongue.
bilyo
#6 posted 10-04-2018 08:50 PM
I think that you are wrong about the frame a panel. I ve used that profile on frame and panel doors quite a bit. It is done with a 45° V-groove bit and a jig on the router that is not hard to make. You make the frame and panel assembly first, then you route the profile around the inside edge. I ll post a picture of the jig later, when I get out to the shop.
- bondogaposis
That’s a nice jig and does a nice job. However, if meecect wants/needs to replicate the profile more precisely, please look again carefully. I believe that the return at the beginning and end of the bevel cut is convex, not cocave. The easy way is to do as you have shown and simply stop the cut leaving a concave profile equal to the radius of the cutter. If he wants a convex return as is the original, I think some chisel work is required.
Smitty got it right. Not sure how it’s done, however.
meecect
3 posts in 473 days
#7 posted 10-04-2018 10:00 PM
As far as wood goes, any thoughts on Jarrah, Cumaru, American Cherry? I agree that Douglas Fir is probably more authentic, but looking for something that will stain beautifully and last a long time.
View Eric's profile
Eric
79 posts in 476 days
#8 posted 10-04-2018 11:16 PM
Pvc boards are easy to cut. But it will also tear out if you are not careful..
I agree Douglas fir for tratrdition, not sure how it will stain up. Oak is another one you could use.
As for the raised panels, I have used a table saw to cut a cove. It takes a little time because you have to make shallow cuts, running the board against a sacrificial fence. It takes time for the correct set up for the look you want. Experiment with it.
For the sidelight frame you may want to make it a bit thicker to accommodate the panels. Also a build up of different trim pieces may work out for you. Again for the look you want.
Good luck on you project
-- Eric, Upstate South Carolina
