Other name for bushing? Where to buy?
Forum topic by Shamb3 posted 10-04-2018 11:02 AM 531 views 0 times favorited 11 replies Add to Favorites Watch
View Shamb3's profile
Shamb3
39 posts in 792 days
10-04-2018 11:02 AM
So I built one project already that called for a bushing and just used some PVC pipe that i cut. It was not a ideal solution but should keep the moving joint from wearing for now.
However, I am seeing again I need a bushing again if I want to build a router lift like in the bellow plan or one like in shop notes issue 121.
https://www.popularwoodworking.com/projects/aw-extra-8912-shop-made-router-lift/
I was able to find bushings at McMastar-Carr but they were like $5 a piece or more.
I seem to have a hard time finding what I want on Amazon. Do they have a more specific name like machine bushings?
11 replies so far
View Redoak49's profile
Redoak49
4358 posts in 2599 days
#1 posted 10-04-2018 11:09 AM
It seems the description calls for bronze bushing. I think the $5 is about right. They are about the same price on eBay.
View TravisH's profile
TravisH
701 posts in 2546 days
#2 posted 10-04-2018 11:27 AM
Ace Hardware has always carried them everywhere I have lived. If you have one near I would check it out. Now it likely will still be cheaper to order from McMaster-Carr.
Shamb3
#3 posted 10-04-2018 11:51 AM
Is a sleeve bearing the same thing as a bushing?
View lumbering_on's profile
lumbering_on
578 posts in 1101 days
#4 posted 10-04-2018 01:20 PM
- Shamb3
Yes, but ‘sleeve bearing’ isn’t a common term from what I’ve seen. A bushing is really a bearing, but just one without any moving parts.
View Richard Lee's profile
Richard Lee
260 posts in 1386 days
#5 posted 10-04-2018 01:22 PM
View diverlloyd's profile
diverlloyd
3765 posts in 2468 days
#6 posted 10-04-2018 01:42 PM
It calls for a flanged bronze bushing 3/4 bore. Lowes has them on their website at $5 a pop. Wonder if these would work instead ?
Short answer is yes they are the same since it a sliding force and not a rolling force being applied.
Redoak49
#7 posted 10-04-2018 01:47 PM
Interesting that a nylon bushing seems to be a similar price as the bronze ones. Of course, you will need a precision shaft to fit the bushing. If you do not have a good fit, you will have slop in the system.
View splintergroup's profile
splintergroup
3220 posts in 1833 days
#8 posted 10-04-2018 01:49 PM
The cheapest source for 3/4”, 5/8”, and 1/2” bushings I have found locally is evaporative cooler bearings (typically only a few bucks each). They are mounted in a pillow block assembly, but you would probably need to modify to remove the rubber isolator.
View MrRon's profile
MrRon
5813 posts in 3854 days
#9 posted 10-04-2018 02:00 PM
https://www.mcmaster.com/catalog/124/1221. These are the typical bushing/bearing used on many projects. They can also be picked up at a local Ace hardware. Most are under a dollar. You can get them either flanged or flangeless. If you buy them from McMaster-Carr, they will cost you more due to shipping and handling. Try a Fastenal store near you, they usually carry them at a good price.
View bandit571's profile
bandit571
24436 posts in 3294 days
#10 posted 10-04-2018 02:05 PM
Tractor Supply Store? They sell a LOT of v belt pulleys,,,and have the bushings to fit….
Shamb3
#11 posted 10-04-2018 10:42 PM
Ok thanks everyone.
It looks like I can find them on Amazon / Ebay under “Bronze Bearing”, “bronze flange bearing”
Or I can find them on McMaster caar for less, but with mystery shipping prices
Or I can find them locally for about the same price at Ace (not confirmed) or Fastenal.
Whenever I do searches online using bushing I get few results and just bearing returns roller blade bearings :)
