How do I change the belt on this lathe?
« back to Woodturning forum
Forum topic by Spankywedwards posted 10-02-2018 08:41 PM 461 views 0 times favorited 2 replies Add to Favorites Watch
View Spankywedwards's profile
Spankywedwards
1 post in 480 days
10-02-2018 08:41 PM
Topic tags/keywords: woodturning lathe belt
I purchased this lathe a couple weeks ago. It runs fine but the belt it came with broke. I can’t for the life of me figure out how to get a new belt on. This machine has no markings. I have no idea what brand it is. If anybody has seen a machine like this any info would be massively helpful. Thank you!
Note; this is as far as I have made it. I cannot figure out how to slide this rod out.
2 replies so far
View MrRon's profile
MrRon
5812 posts in 3852 days
#1 posted 10-02-2018 09:00 PM
Get a link belt. HF has them. You add or take out links to get the right belt length; then install on the lathe and join the ends of the belt together. The arbor is supported on both ends and to use a standard type of belt, requires taking the lathe apart; link belts eliminate this. Link belts run more smoothly than the vee type belt.
View Richard Lee's profile
Richard Lee
260 posts in 1384 days
#2 posted 10-02-2018 09:11 PM
Pictures would help, but do as Ron says and it will save you alot of work.
