Forum topic by jerkylips | posted 10-02-2018 07:10 PM | 711 views | 0 times favorited | 16 replies | ![]() |
When looking at the voltage on a saw/motor, you often see 110/120, as if they are interchangeable. I’ve noticed recently that some brands of cabinet saws are listed as 240v, 230v or 220v. Is there any difference, in terms of wiring requirements? I understand the difference between single phase and 3 phase, but I’m talking strictly single phase. I have a separate panel in the garage, but nothing wired yet – just wondering if it’s something I need to think about before buying or wiring.. |
16 replies so far
#1 posted 10-02-2018 07:53 PM |
Is there any difference, in terms of wiring requirements? No – they are all referring to the same voltage range. Cheers, -- Brad in FL - In Dog I trust... everything else is questionable |
#2 posted 10-02-2018 07:56 PM |
To my understanding – and I’m far from an expert – is that depending on where you live the incoming line voltage can range between 220 and 240 (roughly). For most machines with a simple motor it means almost nothing, maybe a slight variance in HP output of the motor. For some sensitive electronic equipment the variance in voltage can be a problem. In my print shop I have a large production level digital printer that has to be plugged into a voltage converter that steps down our incoming 240 down to 220 for the machine. Apparently it can’t handle 240 V so it needs what’s called a “Power Conditioner” to operate at the correct voltage. But for something like shop equipment you won’t see any real-world difference at all. -- Jarrett - Mount Vernon, Ohio |
#3 posted 10-02-2018 08:28 PM |
Thanks much, everyone! That’s kind of what I thought, but wasn’t really sure. |
#4 posted 10-02-2018 08:31 PM |
For US household wiring, there is no difference. You get voltage from power company they want to give you. :) Most modern homes are supplied either 220VAC or 240VAC single phase. This translates into 110/120 for power from a single leg referenced to neutral. ——————————- The reason for various voltage ratings is due to how power companies reduce the voltage down from transportation voltages (10KV+ 3PH) using various delta and wye transformer configurations. Voltage ratings also have tolerance to allow normal fluctuations due voltage drop under heavily loaded conditions. Power line voltage reduction gets complicated quickly, search wiki if you want to learn more. In industrial wiring (and some old homes); you can find less common 208VAC supply voltage. A 208V supply line can present some unique challenges for large HP industrial motors. There are ‘universal’ replacement motors with voltage taps to allow for differences between 208-240V, but many older motors found on antique woodworking equipment may not. Another consideration is magnetic motor starter required on motors larger than 1.5-2.0HP per code. Motor starter has overload protection circuitry inside that also needs to be modified depending on voltage supplied (usually wire to different tap, but check rating on your box). Running a motor on voltage lower than name plate rating is not recommended as it will cause; power loss, overheating, and premature failure. So depending on equipment being used with 208VAC power, you may have to either; replace 220/240 motor/starter, rewire motor/starter voltage taps, or install a local 208:240V transformer. Best Luck. -- If it wasn't for bad luck, I wouldn't have no luck at all, - Albert King - Born Under a Bad Sign released 1967 |
#5 posted 10-02-2018 09:14 PM |
120VAC and 240VAC are nominal throughout the entire USA. The tolerance permitted varies from location to location but if the voltage in your house reads 110/220 VAC all the time then you have a borderline problem. The terminology is an erroneous holdover from decades ago. |
#6 posted 10-02-2018 09:41 PM |
The voltage we get from the utility company vluctuates during the day because of periods of high usage and non peak hours. It apparently amounts to ± 5 volts. |
#7 posted 10-02-2018 09:43 PM |
#8 posted 10-02-2018 09:53 PM |
Good answer. If you are in north Colorado Springs, you get 119 volts about 95% of the time. I’ve installed a lot of electronics in homes and rarely see anything outside of 115 – 121 volts. -- A severed foot is the ultimate stocking stuffer. |
#9 posted 10-02-2018 10:03 PM |
If you are still in the planning stage with that panel you mentioned, then I would suggest putting in at least one dedicated 240 Volt circuit along with your requirements for 120 Volt GFCI circuits. -- "I build for function first, looks second. Most times I never get around to looks." MIke in CO |
#10 posted 10-02-2018 11:37 PM |
If you feel need to understand differences between various supply voltages found in US power system, might want to read a thread on an electrician’s forum that wanted to know best way to answer the OP question: https://www.electriciantalk.com/f2/208-220-240-a-13116/ Hehe, it is not simple… :) -- If it wasn't for bad luck, I wouldn't have no luck at all, - Albert King - Born Under a Bad Sign released 1967 |
#11 posted 10-02-2018 11:43 PM |
Thanks for bringing back nightmares of the Wye line-to Neutral and Wye line-to-line just when I was over it. :( |
#12 posted 10-03-2018 04:32 AM |
220v is derived as a single phase voltage directly from a local single phase transformer. 208v is derived from a three phase source from two legs of the 3 phase source. Many equipment are sporting universal power supplies that will work from 85v to 250v, sadly electric motors aren’t as flexible. M -- The hump with the stump and the pump! |
#13 posted 10-03-2018 02:22 PM |
Years ago some companies split the difference and list stuff as 115v. Around here my voltage reads 121v but I’ve lived in places where it was closer to 110v. |
#14 posted 10-03-2018 02:37 PM |
We just moved into the house, but the garage walls are still open (not insulated/drywalled yet) because i wasn’t sure where I wanted my stuff set up. I have an electrician friend that said as long as the walls are open, he can easily run some extra lines from the panel. |
#15 posted 10-03-2018 03:20 PM |
No. I’ve wired 208 to labeled 220-240 motors with no issues. -- Shooting down the walls of heartache. Bang bang. I am. The warrior. |
Forum | Topics |
Woodworking Skill Share
13203 |
Woodturning
2815 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1896 |
Finishing
6348 |
7910 |
32777 |
CNC Woodworking
330 |
Hand Tools
6453 |
Jigs & Fixtures
1806 |
Wood & Lumber
7280 |
1633 |
Focus on the Workspace
2637 |
1272 |
Woodworking Trade & Swap
5419 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9660 |
