Stay-put 4" hose that actually holds its position?
Forum topic by JohnMcClure posted 10-02-2018 12:48 AM 844 views 0 times favorited 2 replies Add to Favorites Watch
View JohnMcClure's profile
JohnMcClure
846 posts in 1250 days
10-02-2018 12:48 AM
Topic tags/keywords: dust collection hose stay-put
Can anyone recommend a 4” hose that will hold its position pretty well?
I want one end of the hose clamped onto the blast gate at the back of my workbench, then gooseneck the hose around to wherever I am generating dust – and let it stay there. What I find right now is that the hose end sags toward the floor under gravity’s pull. Particularly when I put a “little gulp” type of hood on the end. I’m willing to get rid of the hood if it’s too heavy, but I want hose that stays where I put it.
Currently I’m using Flexform hose from rockler:
https://www.rockler.com/4-flexform-dust-collection-hose
and I’ve also tried semi-rigid dryer vent hose it’s like corrugated aluminum foil. Tears easily, but is just barely rigid enough to hold its own weight.
What do you recommend? Anyone tried Woodcraft’s “stay-put” hose? It looks the same as Rockler’s flexform…
Oh – and cost is not an issue since this is for my workplace (fume extraction, not dust collection, to be precise).
Thanks!
-- I'd rather be a hammer than a nail
2 replies so far
View Rayne's profile
Rayne
1300 posts in 2149 days
#1 posted 10-02-2018 01:30 AM
Found this while searching for a fully adjustable cantilever arm. I’ve seen someone make one before out of wood that had multiple adjustment points so you could position the hose however you want but I can’t find it right now, but you can imagine how it is built and does work.
Here is a commercial version I accidentally found. Maybe it’ll work for you since cost is not a factor.
http://www.clarcorindustrialair.com/Products/Industrial-Filtration/UAS-DustHog-Collectors/Extraction-Arms-Accessories
Craftsman on the lake
3101 posts in 4047 days
#2 posted 10-02-2018 02:05 AM
I just have regular flexible dust collection hose but a band clamp holds everything onto my blast gates quite well.
