Kreg miter runners binding on crosscut sled
Forum topic by LAdams posted 10-01-2018 10:35 PM 595 views 0 times favorited 3 replies Add to Favorites Watch
View LAdams's profile
LAdams
2 posts in 476 days
10-01-2018 10:35 PM
Topic tags/keywords: kreg miter bars crosscut sled jig tablesaw
I built a crosscut sled, using Kreg “jig & fixture bars” (runners). The sled, after waxing, glides smooth as silk, with no side-to-side play … with just the first and last screws installed. But as soon as I insert any more screws into the centers of the bars, it binds terribly and won’t move. Any idea why this is happening? (I replaced the included 3/4” screws with 1”, but had the same result with both lengths.) The sled will not get much use, so are just these two screws enough? The sled is 24” deep, and there are 5 screw holes. I tried putting a screw into the center hole, and still had the binding problem. Thanks for any insight.
3 replies so far
View Rayne's profile
Rayne
1298 posts in 2143 days
#1 posted 10-01-2018 11:32 PM
Have you made your first cut through the sled yet? Mine also bind until I made the cut and it’s perfectly fine now.
LAdams
2 posts in 476 days
#2 posted 10-01-2018 11:41 PM
Thanks, Rayne… I haven’t made the first cut through it yet. Will try that tomorrow & will re-install the screws. Fingers crossed.
View lumbering_on's profile
lumbering_on
578 posts in 1093 days
#3 posted 10-01-2018 11:46 PM
If that doesn’t work then it sounds like your other screws are pulling the runners out of alignment. If that’s the case, then I’d just leave those screws out and see how it functions. I only have a few screws in my runners as they are only there to keep the runners on the sled.
